Cert Manager integration for Grafana Cloud
cert-manager is a native Kubernetes certificate management controller. It can help with issuing certificates from a variety of sources, such as Let’s Encrypt, HashiCorp Vault, Venafi, a simple signing key pair, or self signed.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Cert Manager metrics.
Before you begin
Cert-manager exposes a prometheus metrics endpoint that is enabled by default.
Install Cert Manager integration for Grafana Cloud
- Find Cert Manager and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Cert Manager metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Cert Manager setup.
Simple mode
These snippets are configured to scrape a single Cert Manager instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_cert_manager" {
targets = [{
__address__ = "localhost:9402",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_cert_manager" {
targets = discovery.relabel.metrics_integrations_integrations_cert_manager.output
job_name = "integrations/cert-manager"
Advanced mode
To instruct Grafana Alloy to scrape your Cert Manager instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Cert Manager instance, you must use a discovery.relabel component to discover your Cert Manager Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Cert Manager Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Cert Manager instance.
If you have multiple Cert Manager servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Cert Manager integration
You should instruct Grafana Agent to scrape your cert-manager nodes.
Cert-manager exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: "integrations/cert-manager"
static_configs:
- targets: ['localhost:9402']
relabel_configs:
- action: replace
replacement: '<your-instance-name>'
target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Cert Manager integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
relabel_configs:
- action: replace
global:
scrape_interval: 60s
Dashboards
The Cert Manager integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Cert Manager
Alerts
The Cert Manager integration includes the following useful alerts:
cert-manager
certificates
Metrics
The most important metrics provided by the Cert Manager integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- certmanager_certificate_expiration_timestamp_seconds
- certmanager_certificate_ready_status
- certmanager_clock_time_seconds
- certmanager_controller_sync_call_count
- certmanager_http_acme_client_request_count
- certmanager_http_acme_client_request_duration_seconds_count
- certmanager_http_acme_client_request_duration_seconds_sum
- container_cpu_cfs_periods_total
- container_cpu_cfs_throttled_periods_total
- container_cpu_usage_seconds_total
- container_memory_usage_bytes
- container_network_receive_bytes_total
- container_network_transmit_bytes_total
- kube_pod_container_resource_limits_cpu_cores
- kube_pod_container_resource_limits_memory_bytes
- kube_pod_container_resource_requests_cpu_cores
- kube_pod_container_resource_requests_memory_bytes
- up
Changelog
Cost
By connecting your Cert Manager instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
