Cert Manager integration for Grafana Cloud
cert-manager is a native Kubernetes certificate management controller. It can help with issuing certificates from a variety of sources, such as Let’s Encrypt, HashiCorp Vault, Venafi, a simple signing key pair, or self signed.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Cert Manager metrics.
Before you begin
Cert-manager exposes a prometheus metrics endpoint that is enabled by default.
Install Cert Manager integration for Grafana Cloud
- Find Cert Manager and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Cert Manager metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Cert Manager setup.
Simple mode
These snippets are configured to scrape a single Cert Manager instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_cert_manager" {
targets = [{
__address__ = "localhost:9402",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_cert_manager" {
targets = discovery.relabel.metrics_integrations_integrations_cert_manager.output
job_name = "integrations/cert-manager"
}Advanced mode
To instruct Grafana Alloy to scrape your Cert Manager instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
}To monitor your Cert Manager instance, you must use a discovery.relabel component to discover your Cert Manager Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your Cert Manager Prometheus metrics endpoint.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Cert Manager instance.
If you have multiple Cert Manager servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Kubernetes instructions
Before you begin with Kubernetes
These instructions assume the use of the Kubernetes Monitoring Helm chart.
Please see official documentation for the Helm chart deployment guide.
Configuration snippets for Kubernetes Helm chart
To scrape your cert-manager instances, modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <> in the provided snippets with your desired configuration values.
Metrics snippets
integrations:
cert-manager:
instances:
- name: cert-manager
labelSelectors:
<cert-manager-pod-label>: <cert-manager-pod-label-value>Dashboards
The Cert Manager integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Cert Manager
Alerts
The Cert Manager integration includes the following useful alerts:
cert-manager
certificates
Metrics
The most important metrics provided by the Cert Manager integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- certmanager_certificate_expiration_timestamp_seconds
- certmanager_certificate_ready_status
- certmanager_clock_time_seconds
- certmanager_controller_sync_call_count
- certmanager_http_acme_client_request_count
- certmanager_http_acme_client_request_duration_seconds_count
- certmanager_http_acme_client_request_duration_seconds_sum
- container_cpu_cfs_periods_total
- container_cpu_cfs_throttled_periods_total
- container_cpu_usage_seconds_total
- container_memory_usage_bytes
- container_network_receive_bytes_total
- container_network_transmit_bytes_total
- kube_pod_container_resource_limits_cpu_cores
- kube_pod_container_resource_limits_memory_bytes
- kube_pod_container_resource_requests_cpu_cores
- kube_pod_container_resource_requests_memory_bytes
- up
Changelog
# 1.0.1 - July 2025
* Update Kubernetes snippets to work with v2.x version of Grafana Monitoring Helm chart.
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.5 - September 2023
# 0.0.4 - March 2023
* Enable cluster template variable
* Add support for kubernetes via Grafana Agent Operator
# 0.0.3 - June 2022
* Unify job name across instructions and alert definition
# 0.0.2 - October 2021
* Update to latest upstream mixin
* Update all rate queries to use `$__rate_interval`, so they respect the default resolution
# 0.0.1 - January 2021
* Initial releaseCost
By connecting your Cert Manager instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
