Catchpoint integration for Grafana Cloud
Catchpoint is a digital experience monitoring platform that provides real-time insights into the performance and availability of websites, applications, and infrastructure. It offers synthetic monitoring, real user monitoring (RUM), and network insights to help organizations proactively detect and resolve issues affecting user experience. Catchpoint enables businesses to ensure optimal performance, minimize downtime, and deliver exceptional digital experiences to their customers.
This integration includes 5 useful alerts and 3 pre-built dashboards to help monitor and visualize Catchpoint metrics.
Before you begin
Catchpoint
To receive data from Catchpoint, you need to set up a webhook that points to the URL where this exporter is running. Follow these steps to configure the webhook in Catchpoint:
- Log in to your Catchpoint account.
- Navigate to Settings > API > Test Data Webhooks.
- Click Add URL.
- Set the “URL” to
http://<your_exporter_address>:<port>/catchpoint-webhook
, where<your_exporter_address>
is the IP address or domain of your server where the exporter is running, and<port>
is configured as per theCATCHPOINT_EXPORTER_PORT
. - Add the template JSON file to set up a test data webhook for the selected metrics.
- Save the webhook configuration.
Next you need to set up the webhook for tests:
- Navigate to Control Center > Tests > Select the Product Properties (or multiple) within the nav section.
- Under the Product Properties section, enable the Test Data Webhook and select the Template you just created.
- Next, under Navigate to Control Center > Tests you will see a list of test names.
- Click on each test name you wish to monitor which brings a window up.
- Under More Settings, enable the Test Data Webhook.
- Under Targeting & Scheduling, set the desired Frequency.
Exporter
To run the Catchpoint Prometheus exporter, run the following commands at the root of the exporter.
go build -o catchpoint-exporter ./cmd/catchpoint-exporter/main.go
./catchpoint-exporter --port="9090" --webhook-path="/catchpoint-webhook --verbosity"
The exporter allows for the configuration of three parameters: port
, webhook-path
, and verbose
port
sets the port on which the exporter will run, defaults to 9090
webhook-path
defines the path where the exporter will receive webhook data from Catchpoint, defaults to /catchpoint-webhook
verbose
enables verbose logging to provide more detailed output for debugging purposes, defaults to false
More information about the exporter can be found here.
Install Catchpoint integration for Grafana Cloud
- Find Catchpoint and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Catchpoint metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Catchpoint setup.
Advanced mode
To instruct Grafana Alloy to scrape your Catchpoint instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
prometheus.scrape "metrics_integrations_integrations_catchpoint" {
targets = [{
__address__ = "<catchpoint-hostname>:<catchpoint-exporter-port>",
job_name = "integrations/catchpoint"
To monitor your Catchpoint instance, you must use a discovery.relabel component to discover your Catchpoint Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Catchpoint Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Catchpoint instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Catchpoint instances to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Catchpoint
- Click Add URL.
- Set the “URL” to
Exporter
, webhook-path
, and verbose
port
webhook-path
verbose
Post-install configuration for the Catchpoint integration
Enable the integration by adding the provided snippets to your agent configuration file.
For the best dashboard experience ensure the following:
job
label must be set tointegrations/catchpoint
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your Catchpoint instance. It is placed automatically by the config snippets.
- job_name: integrations/catchpoint
metrics_path: /metrics
static_configs:
- targets: [<your-instance-name>:<your-exporter-port>]
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Catchpoint integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Catchpoint integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Catchpoint overview
- Catchpoint web performance by node
- Catchpoint web performance by test
Catchpoint overview
Catchpoint overview (connectivity)
Alerts
The Catchpoint integration includes the following useful alerts:
Metrics
The most important metrics provided by the Catchpoint integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- catchpoint_any_error
- catchpoint_cached_count
- catchpoint_client_time
- catchpoint_connect_time
- catchpoint_connection_error
- catchpoint_connections_count
- catchpoint_content_load_time
- catchpoint_css_count
- catchpoint_dns_error
- catchpoint_dns_time
- catchpoint_document_complete_time
- catchpoint_error_objects_loaded
- catchpoint_failed_requests_count
- catchpoint_font_count
- catchpoint_hosts_count
- catchpoint_html_count
- catchpoint_image_count
- catchpoint_load_error
- catchpoint_load_time
- catchpoint_media_count
- catchpoint_redirect_time
- catchpoint_redirections_count
- catchpoint_render_start_time
- catchpoint_requests_count
- catchpoint_response_content_size
- catchpoint_response_header_size
- catchpoint_script_count
- catchpoint_ssl_time
- catchpoint_timeout_error
- catchpoint_total_content_size
- catchpoint_total_header_size
- catchpoint_total_time
- catchpoint_transaction_error
- catchpoint_wait_time
- catchpoint_xml_count
- up
Changelog
# 1.0.1 - November 2024
- Update status panel check queries
# 1.0.0 - June 2024
- Initial release
Cost
By connecting your Catchpoint instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
