Caddy integration for Grafana Cloud
The Caddy web server is an open-source web server written in Go. It uses the Go standard library for its HTTP functionality and supports HTTPS natively.
This integration includes 1 pre-built dashboard to help monitor and visualize Caddy metrics.
Before you begin
In order for the integration to work, you must enable the built-in Prometheus metrics endpoint in Caddy.
If using a Caddyfile, enable metrics in global options:
servers {
metrics
Install Caddy integration for Grafana Cloud
- Find Caddy and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Caddy metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Caddy setup.
Simple mode
These snippets are configured to scrape a single Caddy instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_caddy" {
targets = [{
__address__ = "localhost:2019",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_caddy" {
targets = discovery.relabel.metrics_integrations_integrations_caddy.output
job_name = "integrations/caddy"
Advanced mode
To instruct Grafana Alloy to scrape your Caddy instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Caddy instance, you must use a discovery.relabel component to discover your Caddy Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Caddy Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Caddy instance.
If you have multiple Caddy servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
servers {
metrics
Post-install configuration for the Caddy integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your Caddy nodes.
Caddy exposes a Prometheus endpoint. To scrape it, add the provided config snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/caddy
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: [ 'localhost:2019' ]
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Caddy integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Caddy integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Caddy Overview
Caddy overview
Metrics
The most important metrics provided by the Caddy integration, which are used on the pre-built dashboard, are as follows:
- caddy_http_request_duration_seconds_bucket
- caddy_http_request_duration_seconds_count
- caddy_http_requests_in_flight
- caddy_http_requests_total
- up
Changelog
Cost
By connecting your Caddy instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
