Asterisk integration for Grafana Cloud
Asterisk is a free and open source framework for building communications applications and is sponsored by Sangoma. Asterisk enables the creation of communication applications such as PBX (private branch exchange), VoIP (Voice over Internet Protocol), and conference servers. The Asterisk integration can monitor useful metrics and logs of an asterisk instance.
This integration includes 4 useful alerts and 2 pre-built dashboards to help monitor and visualize Asterisk metrics and logs.
Before you begin
In order for this integration to work, you must enable the embedded Prometheus exporter in Asterisk to collect and expose Asterisk metrics. The embedded Prometheus exporter also requires the embedded Asterisk HTTP server to be enabled.
When both the Asterisk HTTP server and Prometheus exporter are enabled - the metrics are exposed by default on the URL: http://localhost:8088/metrics
To enable logs collection, logging to file must be enabled in asterisk configuration.
Sample res_prometheus configuration /etc/asterisk/prometheus.conf
[general]
enabled = yes
core_metrics_enabled = yes
uri = metrics
Sample http_server configuration /etc/asterisk/http.conf
[general]
enabled=yes
enablestatic=yes
bindaddr=0.0.0.0
bindport=8088
prefix=
sessionlimit=100
session_inactivity=30000
session_keep_alive=15000
Sample file logging configuration in /etc/asterisk/logger.conf
[logfiles]
full => notice,warning,error,verbose,dtmf,fax
Once the configurations are updated, restart the Asterisk server with the following command: sudo systemctl restart asterisk
Check the status of the Asterisk server: sudo systemctl status asterisk
Then login to the Asterisk CLI to verify it’s running: sudo asterisk -r
The metrics should be exposed by the embedded Prometheus exporter on the URL http:/localhost:8088/metrics
Install Asterisk integration for Grafana Cloud
- Find Asterisk and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Asterisk metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Asterisk setup.
Simple mode
These snippets are configured to scrape a single Asterisk instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_asterisk_prom" {
targets = [{
__address__ = "localhost:8088",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_asterisk_prom" {
targets = discovery.relabel.metrics_integrations_integrations_asterisk_prom.output
job_name = "integrations/asterisk-prom"
Logs snippets
darwin
local.file_match "logs_integrations_integrations_asterisk_logs" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/asterisk/full",
instance = constants.hostname,
job = "integrations/asterisk-logs",
loki.source.file "logs_integrations_integrations_asterisk_logs" {
targets = local.file_match.logs_integrations_integrations_asterisk_logs.targets
forward_to = [loki.write.grafana_cloud_loki.receiver]
linux
path_targets = [{
windows
path_targets = [{
Advanced mode
To instruct Grafana Alloy to scrape your Asterisk instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Asterisk instance, you must use a discovery.relabel component to discover your Asterisk Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Asterisk Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Asterisk instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Asterisk servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
path_targets = [{
To monitor your Asterisk instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Asterisk instance address__path__
: The path to the log file. The agent also must be configured to collect logs from thefull
Asterisk log file as shown in the snippet.instance
sets theinstance
loki.source.file sends logs to Loki.
linux
path_targets = [{
__address__
sets theinstance
windows
path_targets = [{
__address__
sets theinstance
[general]
enabled = yes
uri = metrics
[general]
enabled=yes
enablestatic=yes
bindaddr=0.0.0.0
bindport=8088
prefix=
sessionlimit=100
[logfiles]
Post-install configuration for the Asterisk integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Asterisk nodes.
Asterisk exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
The agent also must be configured to collect logs from the full
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/asterisk-prom
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8088']
- job_name: integrations/asterisk-logs
static_configs:
- targets: ['localhost']
labels:
job: integrations/asterisk-logs
instance: '<your-instance-name>'
__path__: /var/log/asterisk/full
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Asterisk integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Asterisk integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Asterisk - Logs
- Asterisk - Overview
Overview
Logs Overview
Channels Information
Alerts
The Asterisk integration includes the following useful alerts:
Metrics
The most important metrics provided by the Asterisk integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- asterisk_bridges_channels_count
- asterisk_bridges_count
- asterisk_calls_count
- asterisk_calls_sum
- asterisk_channels_count
- asterisk_channels_duration_seconds
- asterisk_channels_state
- asterisk_core_last_reload_seconds
- asterisk_core_properties
- asterisk_core_scrape_time_ms
- asterisk_core_uptime_seconds
- asterisk_endpoints_channels_count
- asterisk_endpoints_count
- up
Changelog
Cost
By connecting your Asterisk instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
