Apollo Server integration for Grafana Cloud
Apollo Server is an open-source, spec-compliant GraphQL server that’s compatible with any GraphQL client, including Apollo Client. It’s the best way to build a production-ready, self-documenting GraphQL API that can use data from any source. This integration enables the agent to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 useful alert and 1 pre-built dashboard to help monitor and visualize Apollo Server metrics.
Before you begin
This integration monitors an Apollo Server app that exposes metrics through Apollo Prometheus Exporter.
To expose the metrics you need to instrument your Apollo server:
- Install prom-client and @bmatei/apollo-prometheus-exporter
npm install prom-client @bmatei/apollo-prometheus-exporter
- Create an instance of the plugin:
const app = express();
const prometheusExporterPlugin = createPrometheusExporterPlugin({ app });
- Add the plugin to ApolloServer:
const server = new ApolloServer({
plugins: [prometheusExporterPlugin]
For full instructions and possible setup options please follow the exporter guide.
Install Apollo Server integration for Grafana Cloud
- Find Apollo Server and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apollo Server metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alert to your Grafana Cloud instance, and you can start monitoring your Apollo Server setup.
Simple mode
These snippets are configured to scrape a single Apollo Server instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_apollo_server" {
targets = [{
__address__ = "localhost:4000",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_apollo_server" {
targets = discovery.relabel.metrics_integrations_integrations_apollo_server.output
job_name = "integrations/apollo-server"
Advanced mode
To instruct Grafana Alloy to scrape your Apollo Server instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Apollo Server instance, you must use a discovery.relabel component to discover your Apollo Server Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Apollo Server Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apollo Server instance.
If you have multiple Apollo Server servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Apollo Server integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Apollo Server nodes.
Apollo exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/apollo-server
static_configs:
- targets: ['localhost:4000']
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apollo Server integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
relabel_configs:
global:
scrape_interval: 60s
Dashboards
The Apollo Server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apollo Server Overview
Overview
Alerts
The Apollo Server integration includes the following useful alerts:
Metrics
The most important metrics provided by the Apollo Server integration, which are used on the pre-built dashboard and Prometheus alert, are as follows:
- apollo_query_duration_bucket
- apollo_query_duration_count
- apollo_query_duration_sum
- apollo_query_failed
- apollo_query_field_resolution_duration_count
- apollo_query_field_resolution_duration_sum
- apollo_query_started
- apollo_server_starting
- nodejs_external_memory_bytes
- nodejs_heap_size_total_bytes
- nodejs_heap_size_used_bytes
- nodejs_version_info
- process_cpu_seconds_total
- process_cpu_system_seconds_total
- process_cpu_user_seconds_total
- process_resident_memory_bytes
- process_start_time_seconds
- up
Changelog
Cost
By connecting your Apollo Server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
