Apache Tomcat integration
Apache Tomcat integration for Grafana Cloud
Apache Tomcat is an open source web server and servlet container that can run Java-based web applications. This integration for Grafana Cloud allows users to collect metrics and logs for monitoring an Apache Tomcat instance.
Metrics include virtual memory and cpu usage, traffic sent and received, total requests and processing time, threads, sessions and session processing time, and servlet requests and servlet processing time.
This integration includes 4 useful alerts and 2 pre-built dashboards to help monitor and visualize Apache Tomcat metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the JMX Exporter for Prometheus to export metrics from Tomcat.
To enable JMX collection, make sure your Tomcat instance is configured with the following CATALINA_OPTS:
-Dcom.sun.management.jmxremote
-Dcom.sun.management.jmxremote.port=9010
-Dcom.sun.management.jmxremote.authenticate=false
-Dcom.sun.management.jmxremote.ssl=false
Set up JMX Exporter
The JMX Exporter can be run with this Apache Tomcat JMX Exporter configuration file.
For more information on how to configure the JVM, please refer to the JMX Exporter documentation for further configuration.
Apache Tomcat exposes 9010 for JMX by default, but feel free to change the port to match your environment. The JMX URL for the exporter should be properly configured to match e.g. jmxUrl: service:jmx:rmi:///jndi/rmi://localhost:9010/jmxrmi
Once deployed, Grafana Alloy should be able to reach the JMX Exporter’s exposed endpoint in order to scrape metrics.
Install Apache Tomcat integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Apache Tomcat and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache Tomcat metrics and logs to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache Tomcat setup.
Simple mode
These snippets are configured to scrape a single Apache Tomcat node running locally with default ports.
Manually copy and append the following snippets into your Grafana Alloy configuration file.
Metrics snippets
alloy
discovery.relabel "metrics_integrations_tomcat" {
    targets = [{
        __address__ = "localhost:9010",
    rule {
        target_label = "instance"
prometheus.scrape "metrics_integrations_tomcat" {
    targets    = discovery.relabel.metrics_integrations_tomcat.output
    job_name   = "integrations/tomcat"
Logs snippets
darwin
alloy
local.file_match "logs_integrations_tomcat_linux" {
    path_targets = [{
        __address__ = "localhost",
        __path__    = "/{var,opt,usr/local}/{log,*tomcat*}/{*tomcat*,logs}/catalina.out",
        instance    = constants.hostname,
        job         = "integrations/tomcat",
loki.source.file "logs_integrations_tomcat_linux" {
    targets    = local.file_match.logs_integrations_tomcat_linux.targets
    forward_to = [loki.write.grafana_cloud_loki.receiver]
linux
alloy
    path_targets = [{
windows
alloy
local.file_match "logs_integrations_tomcat_windows" {
    path_targets = [{
        __path__    = "/Program Files/Apache Software Foundation/Tomcat *.*/logs/catalina.out",
loki.source.file "logs_integrations_tomcat_windows" {
    targets    = local.file_match.logs_integrations_tomcat_windows.targets
Advanced mode
To instruct Grafana Alloy to scrape your Apache Tomcat nodes, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, manually copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
Advanced metrics snippets
alloy
    targets = [{
    rule {
After enabling the JMX exporter in your Apache Tomcat node, instruct Grafana Alloy to scrape it.
One discovery.relabel must be added for each Apache Tomcat node.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to the JMX exporter metrics endpoint.
  • instance: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Tomcat instance. Make sure this label value is the same for all telemetry data collected for this instance.
Finally, reference each discovery.relabel component within the targets property of the prometheus.scrape component.
Advanced logs snippets
darwin
alloy
    path_targets = [{
To collect logs from unix-like systems, you need a pair of loki.source.file, and local.file_match components of Grafana Alloy.
The provided snippet is pre-configured with the default log write location for unix-like environments.
If you wish to capture other log files, you must add new maps to the path_targets list parameter of the local.file_match component, and include it in the targets list of loki.source.file component. Make sure that the new entry has the same instance and job labels, so it is matched to the correct instance to be shown in the Logs dashboard.
linux
alloy
    path_targets = [{
windows
alloy
    path_targets = [{
To collect logs from Windows systems, you need a pair of loki.source.file, and local.file_match components of Grafana Alloy.
The provided snippet is pre-configured with the default log write location for Windows environments.
Dashboards
The Apache Tomcat integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Apache Tomcat hosts
  • Apache Tomcat overview
Apache Tomcat overview dashboard 1
Apache Tomcat overview dashboard 2
Apache Tomcat hosts dashboard
Alerts
The Apache Tomcat integration includes the following useful alerts:
AlertDescription
ApacheTomcatAlertsHighCpuUsageCritical: The instance has a CPU usage higher than the configured threshold.
ApacheTomcatAlertsHighMemoryUsageCritical: The instance has a higher memory usage than the configured threshold.
ApacheTomcatAlertsHighRequestErrorPercentCritical: There are a high number of request errors.
ApacheTomcatAlertsModeratelyHighProcessingTimeWarning: The processing time has been moderately high.
Metrics
The most important metrics provided by the Apache Tomcat integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
  • jvm_memory_usage_used_bytes
  • jvm_physical_memory_bytes
  • jvm_process_cpu_load
  • tomcat_bytesreceived_total
  • tomcat_bytessent_total
  • tomcat_errorcount_total
  • tomcat_processingtime_total
  • tomcat_requestcount_total
  • tomcat_servlet_errorcount_total
  • tomcat_servlet_processingtime_total
  • tomcat_servlet_requestcount_total
  • tomcat_session_expiredsessions_total
  • tomcat_session_processingtime_total
  • tomcat_session_rejectedsessions_total
  • tomcat_session_sessioncounter_total
  • tomcat_threadpool_connectioncount
  • tomcat_threadpool_currentthreadcount
  • tomcat_threadpool_keepalivecount
  • tomcat_threadpool_pollerthreadcount
  • up
Changelog
md
# 1.1.1 - November 2024
* Fix metric & log check queries
# 1.1.0 - September 2024
* Added Asserts support
# 1.0.1 - March 2024
* Updated to latest Mixin to fix CPU and Memory Alert queries
# 1.0.0 - October 2023
* Added Grafana Agent Operator configuration snippet to support Tomcat in kubernetes cluster
* Added cluster selector to dashboard for kubernetes support
# 0.0.4 - September 2023
# 0.0.3 - August 2023
# 0.0.2 - July 2023
* Update mixin to latest version
  - Adds an `instance` and `job` filter for the logs panel to only show this integration's logs
# 0.0.1 - April 2023
* Initial release
Cost
By connecting your Apache Tomcat instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
