For more information please check the official guide.
Install Apache HTTP server integration for Grafana Cloud
In your Grafana Cloud stack, click Connections in the left-hand menu.
Find Apache HTTP server and click its tile to open the integration.
Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Apache HTTP server metrics and logs to your Grafana Cloud instance.
Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache HTTP server setup.
Simple mode
These snippets are configured to scrape a single Apache HTTP server instance running locally with default ports.
To instruct Grafana Alloy to scrape your Apache HTTP server instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.apache component to generate metrics from a Apache HTTP server instance.
For the full array of configuration options, refer to the prometheus.exporter.apache component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Apache HTTP server instance to be monitored you must create a pair of these components.
Configure the following properties within each discovery.relabel component:
instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache HTTP server instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel under targets within the prometheus.scrape component.
Metrics are scraped from server-status page.
To enable it, add this code to your httpd.conf configuration file
Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache HTTP server metrics and logs to your Grafana Cloud instance.
Post-install configuration for the Apache HTTP server integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Apache HTTP nodes.
Apache HTTP exposes a /server-status?auto endpoint. To scrape it, add the snippets above to your agent configuration file.
This integration supports metrics and logs from Apache HTTP server. If you want to see your logs and metrics correlated on your dashboards, as a single pane of glass, do the following:
job and instance label values must match for apache_http integration and logs scrape config in the agent configuration file.
job label must be set to integrations/apache_http (already configured in the snippets)
instance label must be set to a value that uniquely identifies your Apache Http Node. Replace <yourhostname> in the snippets with a value appropriate to your environment.
Make sure to change targets in the snippet according to your environment.
Logs are scraped from access.log and error.log files. Make sure to point the agent to these locations.
This integration relies on the Agent exporter, which is provided by default (with a reduced set of metrics) when you installed Grafana Agent.
Replace the existing agent entry with the one provided here.
Below integrations, insert the following lines, following the instructions above:
yaml
apache_http:enabled:trueinstance:'<your-instance-name>'# job is integrations/apache_http by defaultscrape_uri:'http://localhost:8080/server-status?auto'agent:enabled:truemetric_relabel_configs:# required for apache integration.# scraping agent endpoint is required for apache histogram metric collection.-source_labels:[exported_job]target_label: job
-source_labels:[exported_instance]target_label: instance
-regex: (exported_instance|exported_job)
action: labeldrop
Below logs.configs.scrape_configs, insert the following lines according to your environment.
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apache HTTP server integration.
This example also includes metrics that are sent to monitor your Grafana Agent instance.
yaml
integrations:prometheus_remote_write:-basic_auth:password: <your_prom_pass>username: <your_prom_user>url: <your_prom_url># Add here any snippet that belongs to the `integrations` section.# For a correct indentation, paste snippets copied from Grafana Cloud at the beginning of the line.apache_http:enabled:trueinstance:'<your-instance-name>'# job is integrations/apache_http by defaultscrape_uri:'http://localhost:8080/server-status?auto'agent:enabled:truemetric_relabel_configs:# required for apache integration.# scraping agent endpoint is required for apache histogram metric collection.-source_labels:[exported_job]target_label: job
action: labeldrop
logs:configs:-clients:-basic_auth:password: <your_loki_pass>username: <your_loki_user>url: <your_loki_url>name: integrations
positions:filename: /tmp/positions.yaml
scrape_configs:# Add here any snippet that belongs to the `logs.configs.scrape_configs` section.# For a correct indentation, paste snippets copied from Grafana Cloud at the beginning of the line.-job_name: integrations/apache_error
static_configs:-targets:- localhost
labels:__path__: /var/log/apache2/error.log
job: integrations/apache_http
instance:'<your-instance-name>'pipeline_stages:-regex:expression:'^\[[^ ]* (?P<timestamp>[^\]]*)\] \[(?:(?P<module>[^:\]]+):)?(?P<level>[^\]]+)\](?: \[pid (?P<pid>[^\]]*)\])?(?: \[client (?P<client>[^\]]*)\])? (?P<message>.*)$'-labels:module:level:-static_labels:logtype: error
-job_name: integrations/apache_access
labels:__path__: /var/log/apache2/access.log
instance:'<your-instance-name>'pipeline_stages:-regex:expression:'^(?P<ip>[^ ]*) [^ ]* (?P<user>[^ ]*) \[(?P<timestamp>[^\]]*)\] "(?P<method>\S+)(?: +(?P<path>[^ ]*) +\S*)?" (?P<code>[^ ]*) (?P<size>[^ ]*)(?: "(?P<referer>[^\"]*)" "(?P<agent>.*)")?$'-metrics:response_http_codes:type: Histogram
description:"Apache responses by HTTP codes"prefix: apache_
source: code
config:buckets:[199,299,399,499,599]-labels:method:-static_labels:logtype: access
metrics:configs:-name: integrations
remote_write:-basic_auth:password: <your_prom_pass>username: <your_prom_user>url: <your_prom_url>scrape_configs:# Add here any snippet that belongs to the `metrics.configs.scrape_configs` section.# For a correct indentation, paste snippets copied from Grafana Cloud at the beginning of the line.global:scrape_interval: 60s
Dashboards
The Apache HTTP server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
Apache HTTP server
Apache HTTP server logs
Apache HTTP server overview
Apache logs
Alerts
The Apache HTTP server integration includes the following useful alerts:
Alert
Description
ApacheDown
Warning: Apache is down.
ApacheRestart
Info: Apache restart.
ApacheWorkersLoad
Warning: Apache workers load is too high.
ApacheResponseTimeTooHigh
Warning: Apache response time is too high.
ApacheErrorsRateTooHigh
Critical: Apache errors rate is too high.
Metrics
The most important metrics provided by the Apache HTTP server integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
apache_accesses_total
apache_cpuload
apache_duration_ms_total
apache_info
apache_response_http_codes_bucket
apache_response_http_codes_count
apache_scoreboard
apache_sent_kilobytes_total
apache_up
apache_uptime_seconds_total
apache_workers
up
Changelog
md
# 1.0.1 - October 2024
* Update Alloy snippets to properly pass job label from alloy histogram data
# 1.0.0 - July 2024
* Update mixin - fix issue with the HTTP code histogram panel
* Update Alloy snippets to generate HTTP code histograms from access log
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - June 2022
* Initial release
Cost
By connecting your Apache HTTP server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
