Apache HTTP server integration for Grafana Cloud
Apache HTTP server integration is an observability package of dashboards and alerts filled with metrics and logs.
This integration includes 5 useful alerts and 2 pre-built dashboards to help monitor and visualize Apache HTTP server metrics and logs.
Before you begin
Metrics are scraped from server-status page.
To enable it, add this code to your httpd.conf
configuration file
<Location "/server-status">
SetHandler server-status
</Location>
For more information please check the official guide.
Install Apache HTTP server integration for Grafana Cloud
- Find Apache HTTP server and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache HTTP server metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache HTTP server setup.
Simple mode
These snippets are configured to scrape a single Apache HTTP server instance running locally with default ports.
Integrations snippets
Logs snippets
darwin
linux
windows
Advanced mode
To instruct Grafana Alloy to scrape your Apache HTTP server instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.apache component to generate metrics from a Apache HTTP server instance.
For the full array of configuration options, refer to the prometheus.exporter.apache component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Apache HTTP server instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache HTTP server instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
darwin
linux
windows
configuration file
</Location>
Post-install configuration for the Apache HTTP server integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Apache HTTP nodes.
Apache HTTP exposes a /server-status?auto
endpoint. To scrape it, add the snippets above to your agent configuration file.
This integration supports metrics and logs from Apache HTTP server. If you want to see your logs and metrics correlated on your dashboards, as a single pane of glass, do the following:
job
andinstance
label values must match forapache_http
integration andlogs
scrape config in the agent configuration file.job
label must be set tointegrations/apache_http
(already configured in the snippets)instance
label must be set to a value that uniquely identifies your Apache Http Node. Replace<yourhostname>
in the snippets with a value appropriate to your environment.
Make sure to change targets
in the snippet according to your environment.
Logs are scraped from access.log and error.log files. Make sure to point the agent to these locations.
This integration relies on the Agent exporter, which is provided by default (with a reduced set of metrics) when you installed Grafana Agent.
Replace the existing agent
entry with the one provided here.
Below integrations
, insert the following lines, following the instructions above:
apache_http:
enabled: true
instance: '<your-instance-name>'
# job is integrations/apache_http by default
scrape_uri: 'http://localhost:8080/server-status?auto'
agent:
enabled: true
metric_relabel_configs:
# required for apache integration.
# scraping agent endpoint is required for apache histogram metric collection.
- source_labels: [exported_job]
target_label: job
- source_labels: [exported_instance]
target_label: instance
- regex: (exported_instance|exported_job)
action: labeldrop
- job_name: integrations/apache_error
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/apache2/error.log
job: integrations/apache_http
pipeline_stages:
- regex:
expression: '^\[[^ ]* (?P<timestamp>[^\]]*)\] \[(?:(?P<module>[^:\]]+):)?(?P<level>[^\]]+)\](?: \[pid (?P<pid>[^\]]*)\])?(?: \[client (?P<client>[^\]]*)\])? (?P<message>.*)$'
- labels:
module:
level:
- static_labels:
logtype: error
- job_name: integrations/apache_access
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/apache2/access.log
pipeline_stages:
- regex:
expression: '^(?P<ip>[^ ]*) [^ ]* (?P<user>[^ ]*) \[(?P<timestamp>[^\]]*)\] "(?P<method>\S+)(?: +(?P<path>[^ ]*) +\S*)?" (?P<code>[^ ]*) (?P<size>[^ ]*)(?: "(?P<referer>[^\"]*)" "(?P<agent>.*)")?$'
- metrics:
response_http_codes:
type: Histogram
description: "Apache responses by HTTP codes"
prefix: apache_
source: code
config:
buckets: [199,299,399,499,599]
- labels:
method:
- static_labels:
logtype: access
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apache HTTP server integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
apache_http:
enabled: true
agent:
enabled: true
target_label: job
action: labeldrop
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
- targets:
- localhost
labels:
pipeline_stages:
- regex:
- labels:
module:
level:
- static_labels:
logtype: error
static_configs:
- targets:
- localhost
labels:
pipeline_stages:
- regex:
- metrics:
type: Histogram
prefix: apache_
source: code
config:
- labels:
method:
- static_labels:
logtype: access
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Apache HTTP server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache HTTP server
- Apache HTTP server logs
Apache HTTP server overview
Apache logs
Alerts
The Apache HTTP server integration includes the following useful alerts:
Metrics
The most important metrics provided by the Apache HTTP server integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- apache_accesses_total
- apache_cpuload
- apache_duration_ms_total
- apache_info
- apache_response_http_codes_bucket
- apache_response_http_codes_count
- apache_scoreboard
- apache_sent_kilobytes_total
- apache_up
- apache_uptime_seconds_total
- apache_workers
- up
Changelog
Cost
By connecting your Apache HTTP server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
