Apache Hadoop integration
Apache Hadoop integration for Grafana Cloud
Apache Hadoop is an open-source framework designed to process and store large amounts of data across distributed clusters of computers. It provides a scalable and fault-tolerant solution for handling big data by utilizing a distributed file system (Hadoop Distributed File System) and a parallel processing model (MapReduce). This integration for Grafana Cloud allows users to monitor a Hadoop cluster with 4 separate dashboards for visualizing metrics and logs for a Hadoop NameNode, DataNode, NodeManager, and ResourceManager component.
This integration supports Apache Hadoop version 3.3.1+
Apache Hadoop 3.3 and upper supports Java 8 and Java 11 (runtime only)
This integration supports the JMX exporter 0.17.0+
This integration includes 8 useful alerts and 4 pre-built dashboards to help monitor and visualize Apache Hadoop metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the JMX Exporter for Prometheus on each instance in your cluster.
Set up JMX Exporter
Each instance requires a JMX to Prometheus exporter. This is a collector that creates an HTTP server that serves mBean metrics of the local JVM target. Depending on the Apache Hadoop component being monitored - i.e., the NameNode, DataNode, NodeManager and/or ResourceManager - a slightly different configuration will be used. Typically, a DataNode and a NodeManager are grouped together, while the ResourceManager and NameNode are separate. However, each Hadoop deployment architecture may vary.
Expose JMX Remotely
To expose the JMX remotely, it needs to be enabled for the components being monitored. A configuration option enables JMX on the Hadoop daemons, which exists in a hadoop-env.sh file located in the /etc/hadoop/conf. Within the bash file, there is a HDFS_<COMPONENT>_OPTS value that will take an argument to enable JMX, specify the <JMX_PORT>, and manage security options. It should look similar to:
sh
export HDFS_<COMPONENT>_OPTS="-Dcom.sun.management.jmxremote=true -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.port=<JMX_PORT> -Dcom.sun.management.jmxremote.ssl=false"
Then save the configuration file and restart the Hadoop daemons. For more details on setting up an Apache Hadoop cluster environment, refer to the official documentation.
Connect JMX to the Prometheus Exporter
In order to connect JMX to the Prometheus Exporter, a collector is configured in a config file for each component being monitored. This .yaml file, such as namenode.yaml, can be placed anywhere and named anything but must specify the exposed JMX_PORT for the component being monitored. It should look similar to:
sh
hostPort: localhost:<JMX_PORT>
lowercaseOutputName: true
lowercaseOutputLabelNames: true
rules:
    - pattern: ".*"
Run the Prometheus Exporter
To run the JMX to Prometheus exporter, the Java Agent or a Standalone HTTP Server is used. These require two arguments: a .yaml file that was created above and the <JMX_EXPORTER_PORT> that exposes the metrics.
To run the JMX to Prometheus exporter as a Java Agent:
sh
java -javaagent:./jmx_prometheus_javaagent-0.17.0.jar=<JMX_EXPORTER_PORT>:<COMPONENT>.yaml -jar yourJar.jar
To run the JMX to Prometheus exporter as a Standalone HTTP Server:
sh
java -jar jmx_prometheus_httpserver-0.17.0.jar <JMX_EXPORTER_PORT> /path-to-jmx-configs/<COMPONENT>.yaml
To validate that the JMX Exporter is setup correctly, the Prometheus metrics should be available locally via curl:
sh
curl http://localhost:<JMX_EXPORTER_PORT>/metrics
Install Apache Hadoop integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Apache Hadoop and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache Hadoop metrics and logs to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache Hadoop setup.
Advanced mode
To instruct Grafana Alloy to scrape your Apache Hadoop instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
alloy
prometheus.scrape "metrics_integrations_integrations_apache_hadoop" {
	targets = [{
		__address__    = "<your-host-name>:<jmx-exporter-port>",
		hadoop_cluster = "<your-cluster-name>",
		instance       = constants.hostname,
	job_name   = "integrations/apache-hadoop"
To monitor your Apache Hadoop instance, you must use a discovery.relabel component to discover your Apache Hadoop Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to your Apache Hadoop Prometheus metrics endpoint.
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Hadoop instance. Make sure this label value is the same for all telemetry data collected for this instance.
  • hadoop_cluster must be the value that identifies the Apache Hadoop cluster this node belongs to.
If you have multiple Apache Hadoop servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Advanced logs snippets
linux
alloy
local.file_match "logs_integrations_integrations_apache_hadoop" {
	path_targets = [{
		__address__    = "localhost",
		__path__       = "<your-log-path>",
		job            = "integrations/apache-hadoop",
loki.source.file "logs_integrations_integrations_apache_hadoop" {
	targets    = local.file_match.logs_integrations_integrations_apache_hadoop.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your Apache Hadoop instance logs, you will use a combination of the following components:
  • local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
    • __address__: The Apache Hadoop instance address
    • __path__: this is the component log location, which by default is indicated in the HADOOP_LOG_DIR entry within /etc/hadoop/conf config gile. An example log path may look like /hadoop/logs/*.log on Linux.
  • loki.source.file sends logs to Loki.
On Linux, you will also need to add the alloy user to the hadoop group to get logs. Run the following command to configure the user as required:
sh
sudo usermod -a -G hadoop alloy
Dashboards
The Apache Hadoop integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Apache Hadoop DataNode overview
  • Apache Hadoop NameNode overview
  • Apache Hadoop NodeManager overview
  • Apache Hadoop ResourceManager overview
Apache Hadoop NameNode overview (1/2)
Apache Hadoop DataNode overview (1/1)
Apache Hadoop NodeManger overview (1/2)
Alerts
The Apache Hadoop integration includes the following useful alerts:
AlertDescription
ApacheHadoopLowHDFSCapacityWarning: Remaining HDFS cluster capacity is low which may result in DataNode failures or prevent DataNodes from writing data.
ApacheHadoopHDFSMissingBlocksCritical: There are missing blocks in the HDFS cluster which may indicate potential data loss.
ApacheHadoopHDFSHighVolumeFailuresCritical: A volume failure in HDFS cluster may indicate hardware failures.
ApacheHadoopHighDeadDataNodesCritical: Number of dead DataNodes has increased, which could result in data loss and increased network activity.
ApacheHadoopHighNodeManagerCPUUsageCritical: A NodeManager has a CPU usage higher than the configured threshold.
ApacheHadoopHighNodeManagerMemoryUsageCritical: A NodeManager has a higher memory utilization than the configured threshold.
ApacheHadoopHighResourceManagerVirtualCoreCPUUsageCritical: A ResourceManager has a virtual core CPU usage higher than the configured threshold.
ApacheHadoopHighResourceManagerMemoryUsageCritical: A ResourceManager has a higher memory utilization than the configured threshold.
Metrics
The most important metrics provided by the Apache Hadoop integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
  • hadoop_datanode_blocksremoved
  • hadoop_datanode_ramdiskblocksevictedwithoutread
  • hadoop_datanode_volumefailures
  • hadoop_namenode_blockstotal
  • hadoop_namenode_capacityremaining
  • hadoop_namenode_capacitytotal
  • hadoop_namenode_capacityused
  • hadoop_namenode_filestotal
  • hadoop_namenode_missingblocks
  • hadoop_namenode_numdeaddatanodes
  • hadoop_namenode_totalload
  • hadoop_namenode_transactionssincelastcheckpoint
  • hadoop_namenode_underreplicatedblocks
  • hadoop_namenode_volumefailurestotal
  • hadoop_nodemanager_allocatedcontainers
  • hadoop_nodemanager_allocatedgb
  • hadoop_nodemanager_allocatedvcores
  • hadoop_nodemanager_applicationsrunning
  • hadoop_nodemanager_availablegb
  • hadoop_nodemanager_availablevcores
  • hadoop_nodemanager_containerlaunchdurationavgtime
  • hadoop_nodemanager_containerscompleted
  • hadoop_nodemanager_containersfailed
  • hadoop_nodemanager_containersiniting
  • hadoop_nodemanager_containerskilled
  • hadoop_nodemanager_containerslaunched
  • hadoop_nodemanager_containerspaused
  • hadoop_nodemanager_containersreiniting
  • hadoop_nodemanager_containerusedmemgb
  • hadoop_nodemanager_containerusedvmemgb
  • hadoop_nodemanager_gccount
  • hadoop_nodemanager_gctimemillis
  • hadoop_nodemanager_localizationdurationmillisavgtime
  • hadoop_nodemanager_memheapcommittedm
  • hadoop_nodemanager_memheapusedm
  • hadoop_nodemanager_memnonheapcommittedm
  • hadoop_nodemanager_memnonheapusedm
  • hadoop_nodemanager_nodecpuutilization
  • hadoop_nodemanager_nodegpuutilization
  • hadoop_resourcemanager_activeapplications
  • hadoop_resourcemanager_allocatedmb
  • hadoop_resourcemanager_allocatedvcores
  • hadoop_resourcemanager_appscompleted
  • hadoop_resourcemanager_appsfailed
  • hadoop_resourcemanager_appskilled
  • hadoop_resourcemanager_appspending
  • hadoop_resourcemanager_appsrunning
  • hadoop_resourcemanager_appssubmitted
  • hadoop_resourcemanager_availablemb
  • hadoop_resourcemanager_availablevcores
  • hadoop_resourcemanager_gccount
  • hadoop_resourcemanager_gctimemillis
  • hadoop_resourcemanager_memheapcommittedm
  • hadoop_resourcemanager_memheapusedm
  • hadoop_resourcemanager_memnonheapcommittedm
  • hadoop_resourcemanager_memnonheapusedm
  • hadoop_resourcemanager_numactivenms
  • hadoop_resourcemanager_numdecommissionednms
  • hadoop_resourcemanager_numlostnms
  • hadoop_resourcemanager_numrebootednms
  • hadoop_resourcemanager_numshutdownnms
  • hadoop_resourcemanager_numunhealthynms
  • up
Changelog
md
# 1.0.0 - August 2024
* Add Kubernetes as a supported platform using Grafana Alloy
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial release
Cost
By connecting your Apache Hadoop instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
