Apache CouchDB integration for Grafana Cloud
Apache CouchDB is a NoSQL document-oriented database system known for its scalability, availability, and easy replication of data across multiple servers. This integration for Grafana Cloud allows users to collect metrics and system logs for monitoring an Apache CouchDB instance or clustered deployment. This integration also includes useful visualizations for both cluster and node metrics such as open databases, database writes/reads, request latency, request rates, response statuses, and replicator failure info.
This integration supports Apache CouchDB versions 3.2.x+.
This integration includes 10 useful alerts and 2 pre-built dashboards to help monitor and visualize Apache CouchDB metrics and logs.
Before you begin
In order for the integration to properly work, one of two configurations changes must occur. Either a user must be given metric permissions or the unauthenticated Prometheus endpoint must be setup.
Granting metrics permissions to a user
If an admin user and password is not planned on being used in the metric configuration, a CouchDB user must instead be given the _metrics
role when creating a new user.
Example
curl http://localhost:5984/_users/org.couchdb.user:prom_user \
-X PUT \
-u admin:password \
-H "Content-Type: application/json" \
-d '{"name":"prom_user", "password":"prom_password", "roles": ["_metrics"], "type": "user"}'
Configuring the unauthenticated Prometheus endpoint
To enable the unauthenticated Prometheus endpoint for each node, CouchDB’s configuration file local.ini
must be updated to include the correct Prometheus configuration.
Example
[prometheus]
additional_port = true
bind_address = 127.0.0.1
port = 17986
Install Apache CouchDB integration for Grafana Cloud
- Find Apache CouchDB and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache CouchDB metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache CouchDB setup.
Advanced mode
To instruct Grafana Alloy to scrape your Apache CouchDB instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Apache CouchDB instance, you must use a discovery.relabel component to discover your Apache CouchDB Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Apache CouchDB Prometheus metrics endpoint. The ports for the targets should be changed based on if you are using the authenticated endpoint (default5984
) or the unauthenticated Prometheus endpoint (default17986
).instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache CouchDB instance. Make sure this label value is the same for all telemetry data collected for this instance.couchdb_cluster
: Thecouchdb_cluster
label to group your Apache CouchDB instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Apache CouchDB servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Beware that the prometheus.scrape
component must hold the auth information if your are running an autheticated Prometheus endpoint. Check the component documentation for the different auth options.
Advanced logs snippets
darwin
local.file_match "logs_integrations_integrations_apache_couchdb" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/couchdb/couchdb.log",
couchdb_cluster = "<your-cluster-name>",
instance = constants.hostname,
job = "integrations/apache-couchdb",
loki.process "logs_integrations_integrations_apache_couchdb" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.multiline {
firstline = "\\[[a-z]+\\] \\d+-\\d+-\\d+T\\d+:\\d+:\\d+\\.\\d+"
max_lines = 0
max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_apache_couchdb" {
targets = local.file_match.logs_integrations_integrations_apache_couchdb.targets
forward_to = [loki.process.logs_integrations_integrations_apache_couchdb.receiver]
To monitor your Apache CouchDB instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Apache CouchDB instance address__path__
: The path to the log file.instance
sets theinstance
- loki.process defines how to process logs before sending it to Loki.
- loki.source.file sends logs to Loki.
On Linux, you will also need to add the alloy
user to the couchdb
group to get logs. Run the following command to configure the user as required:
sudo usermod -a -G couchdb alloy
linux
path_targets = [{
stage.multiline {
max_lines = 0
__address__
sets theinstance
user to the couchdb
windows
path_targets = [{
__path__ = "/Program Files/Apache Software Foundation/CouchDB/var/log/couchdb.log",
stage.multiline {
max_lines = 0
__address__
sets theinstance
Example
-X PUT \
-u admin:password \
Example
[prometheus]
port = 17986
Post-install configuration for the Apache CouchDB integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your Apache CouchDB nodes.
If the unauthenticated Prometheus endpoint is being used for CouchDB, basic_auth
should be removed from your metrics scrape_configs
If using the authenticated endpoint for CouchDB, replace the username
and password
values with the correct CouchDB user and password.
If CouchDB requires any aditional security measures to connect to the authenticated prometheus endpoint, then make sure to add any additional auth configuration to the metrics scrape_configs.
Make sure to change targets
in the snippet according to your environment. The ports for the targets should be changed based on if you are using the authenticated endpoint (default 5984
) or the unauthenticated Prometheus endpoint (default 17986
You must also configure a custom label for this integration that much be attached to each of the targets:
couchdb_cluster
, the value that identifies a Apache CouchDB cluster
You can define a cluster label by adding an extra label to the scrape_configs of the metric configuration.
For the logs section, ensure the file path of the CouchDB system log is correct.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andinstance
label values must match for the Apache CouchDB integration and logs scrape config in your agent configuration file.job
must be set tointegrations/apache-couchdb
instance
label must be set to a value that uniquely identifies your Apache CouchDB node. Please replace the default hostname value according to your environment - it should be set manually. Note that if you use localhost for multiple nodes, the dashboards will not be able to filter correctly by instance.couchdb_cluster
must be the value that identifies the Apache CouchDB cluster this node belongs to.
On Linux, you will also need to add the grafana-agent
user to the couchdb
sudo usermod -a -G couchdb grafana-agent
- job_name: integrations/apache-couchdb
metrics_path: /_node/_local/_prometheus
basic_auth:
username: '<couchdb_user>'
password: '<couchdb_password>'
static_configs:
- targets: ['<your-node-hostname1>:5984']
- targets: ['<your-node-hostname2>:5984']
- targets: ['<your-node-hostname3>:5984']
relabel_configs:
- target_label: couchdb_cluster
replacement: '<your-cluster-name>'
- target_label: instance
replacement: '<your-instance-name>'
static_configs:
- targets: [localhost]
labels:
job: integrations/apache-couchdb
couchdb_cluster: '<your-cluster-name>'
instance: '<your-instance-name>'
# For a Windows installation this path should be changed to:
# /Program Files/Apache Software Foundation/CouchDB/var/log/couchdb.log
__path__: /var/log/couchdb/couchdb.log
pipeline_stages:
- multiline:
# match on severity date like '[notice] 2022-01-01T12:12:12.11111'
# but feel free to modify to match your logs
firstline: '\[[a-z]+\] \d+-\d+-\d+T\d+:\d+:\d+\.\d+'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apache CouchDB integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Apache CouchDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache CouchDB nodes
- Apache CouchDB overview
Apache CouchDB overview (1/2)
Apache CouchDB overview (2/2)
Apache CouchDB nodes (1/2)
Alerts
The Apache CouchDB integration includes the following useful alerts:
Metrics
The most important metrics provided by the Apache CouchDB integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- couchdb_couch_log_requests_total
- couchdb_couch_replicator_changes_manager_deaths_total
- couchdb_couch_replicator_changes_queue_deaths_total
- couchdb_couch_replicator_changes_reader_deaths_total
- couchdb_couch_replicator_cluster_is_stable
- couchdb_couch_replicator_connection_owner_crashes_total
- couchdb_couch_replicator_connection_worker_crashes_total
- couchdb_couch_replicator_jobs_crashes_total
- couchdb_couch_replicator_jobs_pending
- couchdb_database_reads_total
- couchdb_database_writes_total
- couchdb_erlang_memory_bytes
- couchdb_httpd_bulk_requests_total
- couchdb_httpd_request_methods
- couchdb_httpd_status_codes
- couchdb_httpd_temporary_view_reads_total
- couchdb_httpd_view_reads_total
- couchdb_httpd_view_timeouts_total
- couchdb_open_databases_total
- couchdb_open_os_files_total
- couchdb_request_time_seconds
- couchdb_request_time_seconds_count
- couchdb_request_time_seconds_sum
- up
Changelog
# 1.0.0 - May 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
* Bump version to 1.0.0
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - April 2023
* Initial release
Cost
By connecting your Apache CouchDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
