Apache Airflow integration for Grafana Cloud
Apache Airflow is an open-source platform for programmatically authoring, scheduling, and monitoring workflows, enabling the orchestration of complex data pipelines and task dependencies. This integration for Grafana Cloud allows users to collect metrics, scheduler logs, and task logs for monitoring an Apache Airflow system.
Metrics include DAG (Directed Acyclic Graph) failures, DAG durations, task failures, task durations, scheduler details, executor tasks, and pool task slots for an Apache Airflow system.
This integration supports Apache Airflow versions 2.5.0+.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Apache Airflow metrics and logs.
Before you begin
In order for the integration to properly work, Airflow must be setup to send metrics to StatsD.
Setup Airflow to send metrics to StatsD
First you must install the StatsD requirement:
pip install 'apache-airflow[statsd]'
Also, the following lines must be added to your airflow.cfg:
[metrics]
statsd_on = True
statsd_host = localhost
statsd_port = 8125
statsd_prefix = airflow
Install Apache Airflow integration for Grafana Cloud
- Find Apache Airflow and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache Airflow metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Apache Airflow setup.
Simple mode
These snippets are configured to scrape a single Apache Airflow instance running locally with default ports.
Integrations snippets
prometheus.exporter.statsd "integrations_statsd_exporter" {
listen_udp = "localhost:8125"
mapping_config_path = "statsd_mapping.yaml"
discovery.relabel "integrations_statsd_exporter" {
targets = prometheus.exporter.statsd.integrations_statsd_exporter.targets
rule {
target_label = "job"
replacement = "integrations/apache-airflow"
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "integrations_statsd_exporter" {
targets = discovery.relabel.integrations_statsd_exporter.output
job_name = "integrations/statsd_exporter"
Advanced mode
To instruct Grafana Alloy to scrape your Apache Airflow instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
This integration uses the prometheus.exporter.statsd component to generate metrics from a Apache Airflow instance.
Make sure to change listen_udp
in the snippet according to your environment.
The statsd exporter component requires an external mapping configuration file. You can download the correct mapping file for this integration here.
If you’re deploying to Kubernetes using the official helm chart, the statsd exporter is included with a custom mapping configuration, but the configuration will need to be updated.
For the full array of configuration options, refer to the prometheus.exporter.statsd component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Apache Airflow instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Airflow instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
darwin
To monitor your Apache Airflow instance logs, you will use a combination of the following components:
If you’re deploying to Kubernetes using the official helm chart, the scheduler and task logs will need to be persisted to a volume and an additional Alloy pod will need to be deployed with those volumes mounted.
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Apache Airflow instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
Kubernetes sidecars for log collection
If you’re running Airflow using the official helm chart, additional steps are required for collecting logs from the environment.
ConfigMaps
You’ll want to clone down the repo, as the extraConfigMaps
configuration in values.yaml
is not suitable. You’ll have to add additional YAML
files to the /templates/configmaps
directory.
Here are examples from the sample application for the Alloy configurations that will need to be tailored to your environment.
Sidecars
To setup the Alloy sidecars for the task and scheduler logs, you’ll update the values.yaml
file. There are extraContainers
sections for the worker and scheduler pods.
Here’s example YAML for the task logs sidecar container. It will be Alloy with volume mounts for the custom alloy configuration and the Airflow logs directory.
extraContainers:
- name: alloy
image: grafana/alloy:latest
volumeMounts:
- name: alloy-task-logs-config
mountPath: /etc/alloy/config.alloy
subPath: config.alloy
- name: logs
mountPath: /opt/airflow/logs/
securityContext:
runAsUser: 0
runAsGroup: 0
Following the addition of the Alloy configurations and the Alloy sidecars, log collection should be working.
linux
__address__
sets theinstance
ConfigMaps
directory.
Sidecars
extraContainers:
- name: alloy
volumeMounts:
- name: logs
securityContext:
runAsUser: 0
runAsGroup: 0
[metrics]
statsd_on = True
statsd_port = 8125
Post-install configuration for the Apache Airflow integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your Apache Airflow system.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andinstance
label values must match for the Apache Airflow integration and logs scrape config in your agent configuration file.job
must be set tointegrations/apache-airflow
. Ensure that thejob
under theagent
relabel_configs
matches thejob
labels under thelogs
static_configs
as well as thepipeline_stages
match
selector
.instance
label must be set to a value that uniquely identifies your Apache Airflow system. Ensure that theinstance
under theagent
statsd_exporter
matches theinstance
static_configs
match
selector
Below integrations
- job_name: integrations/apache-airflow
static_configs:
- targets: [localhost]
labels:
job: integrations/apache-airflow
instance: '<your-instance-name>'
__path__: '<airflow_home>/logs/dag_id=*/**/*.log'
labels:
__path__: '<airflow_home>/logs/scheduler/latest/*.py.log'
pipeline_stages:
- match:
selector: '{job="integrations/apache-airflow",instance="<your-instance-name>"}'
stages:
- regex:
source: filename
expression: "<airflow_home>/logs/dag_id=(?P<dag_id>\\S+?)/.*/task_id=(?P<task_id>\\S+?)/.*log"
- labels:
dag_id:
task_id:
- match:
stages:
- regex:
source: filename
expression: "<airflow_home>/logs/scheduler/latest/(?P<dag_file>\\S+?)\\.log"
- labels:
dag_file:
- multiline:
# match on timestamp. Format should be like '[2023-05-09T11:58:53.205+0000]'
firstline: '\[\d+-\d+-\d+T\d+:\d+:\d+\.\d+\+\d+\]'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apache Airflow integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Apache Airflow integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache Airflow overview
Apache Airflow overview (general)
Apache Airflow overview (scheduler)
Alerts
The Apache Airflow integration includes the following useful alerts:
Metrics
The most important metrics provided by the Apache Airflow integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- airflow_dag_processing_import_errors
- airflow_dag_task_duration_count
- airflow_dag_task_duration_sum
- airflow_dagrun_duration_failed_count
- airflow_dagrun_duration_failed_sum
- airflow_dagrun_duration_success_count
- airflow_dagrun_duration_success_sum
- airflow_dagrun_schedule_delay_count
- airflow_dagrun_schedule_delay_sum
- airflow_executor_open_slots
- airflow_executor_queued_tasks
- airflow_executor_running_tasks
- airflow_pool_open_slots
- airflow_pool_queued_slots
- airflow_pool_running_slots
- airflow_pool_starving_tasks
- airflow_scheduler_tasks_executable
- airflow_scheduler_tasks_starving
- airflow_sla_missed
- airflow_task_finish_total
- airflow_task_start_total
- airflow_ti_failures
- up
Changelog
# 1.0.0 - June 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
# 0.0.4 - September 2023
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - June 2023
* Initial release
Cost
By connecting your Apache Airflow instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
