AI Observability integration
AI Observability integration for Grafana Cloud
AI Observability Integration for Grafana Cloud provides a comprehensive solution for monitoring and analyzing the performance of AI models. This integration allows users to collect and visualize key metrics related to AI, including LLM operations and GPU usage.
This integration includes 2 pre-built dashboards to help monitor and visualize AI Observability metrics.
Dashboards
The AI Observability integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • GPU Monitoring
  • GenAI Observability
Metrics
The most important metrics provided by the AI Observability integration, which are used on the pre-built dashboards, are as follows:
  • db_requests_total
  • gen_ai_requests_total
  • gen_ai_usage_completion_tokens_total
  • gen_ai_usage_cost_USD_bucket
  • gen_ai_usage_cost_USD_sum
  • gen_ai_usage_input_tokens_total
  • gen_ai_usage_tokens_total
  • gpu_dec_utilization
  • gpu_enc_utilization
  • gpu_fan_speed
  • gpu_memory_available
  • gpu_memory_free
  • gpu_memory_total
  • gpu_memory_used
  • gpu_power_draw
  • gpu_power_limit
  • gpu_temperature
  • gpu_utilization
  • up
Changelog
md
# 0.0.1 - September 2024
* Initial release
Cost
By connecting your AI Observability instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
