Aerospike integration for Grafana Cloud
Aerospike is a high-performance, NoSQL, key-value database designed for ultra-low-latency and high-throughput applications. It offers fast data storage and retrieval, scalability, and ACID compliance, making it suitable for real-time, mission-critical data processing.
This integration supports Aerospike versions 6.2.0+
This integration includes 8 useful alerts and 4 pre-built dashboards to help monitor and visualize Aerospike metrics and logs.
Before you begin
Aerospike
This integration is designed to target clustered Aerospike environments. For best results, namespaces within a single cluster should have unique names.
By default, Aerospike logs to STDERR. To enable log collection for your Aerospike instance, create the /var/log/aerospike
directory and modify the logging section of the instance’s aerospike.conf
file to send logs to a file. Save these changes and restart Aerospike to begin logging to a file.
context any
instructs Aerospike to capture log messages from all contexts. For a full list of logging contexts, see this documentation.info
instructs Aerospike to capture log messages of severity level info or higher. Other possible values arecritical
,warning
,debug
, anddetail
This example is the recommended configuration for an Aerospike instance, but if your log file path or name differs, modify your configuration accordingly.
logging {
file /var/log/aerospike/aerospike.log {
context any info
Certain metrics used in this integration may not appear depending on your Aerospike instance’s configuration (aerospike.conf
- to monitor disk metrics, one or more namespaces must be configured to use
storage-engine device
- to monitor cache metrics, one or more namespace must be configured to use
withdata-in-memory false
Example namespace configuration:
namespace test {
replication-factor 2
memory-size 1G
storage-engine device {
file /opt/aerospike/data/test.data
filesize 1G
read-page-cache true
Aerospike prometheus exporter
This integration supports metrics and logs from an Aerospike instance. It is configured to work with the Aerospike Prometheus Exporter, which must be installed and configured separately from Grafana Alloy.
To export logs from your Aerospike instance, modify the logging configuration section of ape.toml
log_file = "/var/log/aerospike/aerospike.log"
log_level = "info"
Install Aerospike integration for Grafana Cloud
- Find Aerospike and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Aerospike metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Aerospike setup.
Advanced mode
To instruct Grafana Alloy to scrape your Aerospike instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
prometheus.scrape "metrics_integrations_integrations_aerospike" {
targets = [{
__address__ = "<node-hostname>:9145",
aerospike_cluster = "<as-cluster-name>",
job_name = "integrations/aerospike"
To monitor your Aerospike instance, you must use a discovery.relabel component to discover your Aerospike Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Aerospike Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Aerospike instance. Make sure this label value is the same for all telemetry data collected for this instance.aerospike_cluster
: Theaerospike_cluster
label to group your Aerospike instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Aerospike servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
To monitor your Aerospike instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Aerospike instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
Aerospike
context any
,warning
,debug
, anddetail
logging {
context any info
namespace test {
memory-size 1G
filesize 1G
This integration supports metrics and logs from an Aerospike instance. It is configured to work with the Aerospike Prometheus Exporter, which must be installed and configured separately from the Grafana Agent.
log_level = "info"
Post-install configuration for the Aerospike integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your Aerospike Prometheus Exporter.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
,aerospike_cluster
, andinstance
label values must match for metrics and logs scrape config in your agent configuration file.job
label must be set tointegrations/aerospike
(already configured in the snippets).aerospike_cluster
label must be set to a value that identifies your Aerospike cluster.instance
label must be set to a value that uniquely identifies your Aerospike node. Please replace the default hostname value according to your environment - it must be set manually.
- job_name: integrations/aerospike
metrics_path: /metrics
static_configs:
- targets: ["<node-hostname>:9145"]
labels:
aerospike_cluster: '<as-cluster-name>'
static_configs:
- targets: [localhost]
labels:
job: integrations/aerospike
instance: '<node-hostname>:9145'
__path__: /var/log/aerospike/aerospike.log
pipeline_stages:
- multiline:
firstline: '\w{3} \d{2} \d{4}'
- regex:
expression: '\w{3} \d{2} \d{4} \d{2}:\d{2}:\d{2} \w{3}: (?P<level>\w+) \((?P<context>\w+)\): (?P<trace>\(\S+\))\s+(?P<message>(?s:.*))$'
- labels:
level:
context:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Aerospike integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
pipeline_stages:
- multiline:
- regex:
- labels:
level:
context:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
labels:
global:
scrape_interval: 60s
Dashboards
The Aerospike integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Aerospike instance overview
- Aerospike logs
- Aerospike namespace overview
- Aerospike overview
Aerospike overview (cluster overview)
Aerospike overview (client requests)
Aerospike logs (logs)
Alerts
The Aerospike integration includes the following useful alerts:
Metrics
The most important metrics provided by the Aerospike integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- aerospike_namespace_cache_read_pct
- aerospike_namespace_client_read_error
- aerospike_namespace_client_read_filtered_out
- aerospike_namespace_client_read_not_found
- aerospike_namespace_client_read_success
- aerospike_namespace_client_read_timeout
- aerospike_namespace_client_udf_complete
- aerospike_namespace_client_udf_error
- aerospike_namespace_client_udf_filtered_out
- aerospike_namespace_client_udf_timeout
- aerospike_namespace_client_write_error
- aerospike_namespace_client_write_filtered_out
- aerospike_namespace_client_write_success
- aerospike_namespace_client_write_timeout
- aerospike_namespace_clock_skew_stop_writes
- aerospike_namespace_dead_partitions
- aerospike_namespace_device_free_pct
- aerospike_namespace_memory_free_pct
- aerospike_namespace_ns_cluster_size
- aerospike_namespace_stop_writes
- aerospike_namespace_unavailable_partitions
- aerospike_namespace_xmem_id
- aerospike_node_stats_client_connections
- aerospike_node_stats_fabric_connections
- aerospike_node_stats_heap_efficiency_pct
- aerospike_node_stats_heartbeat_connections
- aerospike_node_stats_system_free_mem_pct
- aerospike_node_up
- up
Changelog
# 0.0.2 - November 2024
- Update status panel check queries
# 0.0.1 - September 2023
- Initial release
Cost
By connecting your Aerospike instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
