Errors overview
Errors overview
Errors overview
The Errors page displays errors reported using the Faro Web SDK. You can search, filter, and sort errors. Clicking an error displays more context on the error.
Filter, search, and sort
At the top of the errors list, you can:
  • Filter errors by app to see errors produced by a specific application.
  • Search errors by error type and message.
  • Change the sort order.
Error context
Error details view showing details of an error.
Click an error to view additional context including the timestamp, metadata like session id and browser info, and any stack traces for the error.
If there are multiple collected instances of the error, you can click the newer and older buttons to view each instance.
