Integrate Application Observability with Frontend Observability
You can integrate Application Performance Monitoring (APM) with Real User Monitoring (RUM) and include services that are monitored with Grafana Cloud Frontend Observability in the Service Map and Service Graph.
A Service Map that includes services monitored with Frontend Observability
Enable WebApps in the Application Observability configuration
  1. Navigate to Observability > Application > Configuration in your Grafana Cloud Instance.
  2. Select the Settings tab.
  3. Enable Include Webapps and Mobile Devices.
After enabling Webapps and Mobile Devices on the Configuration page, you can:
  • easily navigate between Application Observability Services and Real User Monitoring services.
  • navigate between traces in Application Observability and user sessions in Frontend Observability.
For more details, refer to the Frontend Observability documentation on the APM integration.
