Plugins 〉Compact Hostmap Panel
Compact Hostmap Panel for Grafana
Grafana Panel Plugin to easily understand the host's system metric at a glance
Supported Datasources
- promethues
- elasticsearch
tested.
Supports Grafana plugin interface data frames, groupBy each frame based on name || field's config.displayName || config.displayNameFromDS field's key.
ETC
HostItem is rendered in response to panel size, and Color Threshold is mapped to the largest value.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Compact Hostmap Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Compact Hostmap Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
0.9.0 (Unreleased)
Initial release.
