Plugins
PanelCommunity
Boom Theme logo
Boom Theme
Sriramajeyam Sugumaran
Get plugin
This plugin has been deprecated and is no longer maintained.
Boom Theme Panel
Build & Publish Release
Theme switcher with custom styles / themes for grafana dashboards.
image image
Features
  • Theme switcher
  • Multiple themes per dashboard
  • Theme builder
  • External stylesheets support
  • Add inline styles to themes to override styles
  • Add many themes as possible without rebuilding / restarting grafana
  • Users can change the themes without editing the dashboard
  • Dashboard specific themes
Creating Theme
Themes can be created with multiple building blocks like background image, base theme etc.
Property Description
Base theme Themes can be built on top of default/dark/light theme. Default is Default Theme
Background image Optional property. Can be blank. If specified more than once, last wins. Value should be valid image URL
CSS url External theme file. Should be valid CSS file URL
Custom Style / CSS Override CSS Styles. Should be valid css
Panel container BG Background color for the panels
Supported Grafana version
This grafana plugin is tested with the following grafana versions, But other versions are also expected to work.
  • Grafana version 8.x
  • Grafana version 7.x
  • Grafana version 6.x
Notes
  • When adding external stylesheets, make sure CORS enabled for those domains.
  • To make panel invisible : Modify following theme panel settings:
    • transparent = true
    • title = ""
    • Disable Theme Picker using panel settings
    • Move this panel to the bottom of the dashboard
    • Adjust the height and width if required.
Known issues / Limitations
  • If any custom plugin is used, dark/light theme switch, base theme will not work for those custom plugins. Refer this github issue
  • Theme panel should be within view port. Otherwise, Grafana won't render the theme. Refer this
Installation Instructions
There are multiple ways to install this plugin into your grafana instance
Download and extract zip file
Download the zip file from github releases page and extract into your grafana plugin folder. Then restart Grafana.
Using grafana-cli
If you are using grafana-cli, execute the following command to install the plugin
grafana-cli plugins install yesoreyeram-boomtheme-panel
or for specific versions
grafana-cli --pluginUrl https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/releases/download/v0.2.1/yesoreyeram-boomtheme-panel-0.2.1.zip plugins install yesoreyeram-boomtheme-panel
Using helm chart
If you use helm chart to provision grafana, use the following config to install the plugin
plugins:
  - yesoreyeram-boomtheme-panel
or for any specific versions
plugins:
  - https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/releases/download/v0.2.1/yesoreyeram-boomtheme-panel-0.2.1.zip;yesoreyeram-boomtheme-panel
Insights
  • Adoption
    Running on 31,454 active Grafana instances.
  • Activity
    Last updated 18 Dec 2023.
    0 releases in the past year.
Version
0.2.1
Dependencies
  • Grafana >7.5.0
Developer
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
