Plugins 〉Business Satellite
Business Satellite
Business Satellite for Grafana
Announcement
We are announcing the retirement of the Business Satellite data source, effective as of today, July 12, 2025, as part of our commitment to maintaining a modern and efficient Grafana plugin ecosystem. To ensure continued access to your data and analytics, we strongly recommend migrating to the Infinity data source, a powerful and flexible alternative designed to meet your evolving needs.
Why This Change?
The retirement of the Business Satellite data source reflects our focus on consolidating resources toward scalable, future-proof solutions. The Infinity data source provides enhanced support for diverse data formats, real-time updates, and seamless integration with Grafana 11 and 12, addressing limitations in the older plugin.
Overview
The Business Satellite data source plugin for Grafana enables seamless access to data from local and remote Grafana instances via the HTTP API. Designed for flexibility and ease of use, it integrates with Grafana to retrieve health information, annotations, alerts, and other data source details.
Compatibility
- Version 3.x: Requires Grafana 10.2 or Grafana 11.
- Version 2.x: Compatible with Grafana 9 and Grafana 10.
- Version 1.x: Works with Grafana 8.5 and Grafana 9.
Installation
Install the Business Satellite data source from the Grafana Plugin Catalog or via the Grafana CLI:
grafana cli plugins install volkovlabs-grapi-datasource
Need help? Check out our installation guide:
Setup
To connect, provide a Grafana URL and an API key or token. This authenticates the plugin with your Grafana organization and enables data retrieval.
Key Features
- Connects to local and remote Grafana instances via HTTP API.
- Retrieves health status, annotations, alerts, and data sources.
- Supports API keys and tokens for secure authentication.
Documentation
Explore detailed guides and resources:
| Section | Description |
| Configuration | Set up the data source with ease. |
| Provisioning | Automate setup for your environment. |
| Features | Discover what the plugin can do. |
| Release Notes | Track updates and new features. |
Business Suite for Grafana
The Business Satellite plugin is part of the Business Suite, a collection of open-source plugins by Volkov Labs. These tools solve common business challenges with intuitive interfaces, detailed docs, and video tutorials.
Enterprise Support
Upgrade to Business Suite Enterprise for premium support, including:
- Dedicated support via Zendesk.
- Priority feature requests and bug fixes.
- In-person consultations and Business Intelligence access.
Get Involved
We’d love to hear from you:
- Questions or Bugs: File them on GitHub Issues.
- Stay Updated: Subscribe to our YouTube Channel.
License
Licensed under the Apache License 2.0.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Business Satellite on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Business Satellite from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Change Log
3.6.0 (2025-07-12)
Why This Change?
3.5.0 (2025-04-03)
Features & Enhancements
- Added starred filtering to dashboard search request type (#88)
- Enabled filtering of annotation results using tags (#89)
- Upgraded to Grafana 11.5 and updated dependencies (#91)
3.4.0 (2024-12-25)
- Updated E2E tests for reliability (#83)
- Upgraded to Grafana 11.4 and updated dependencies (#84)
3.3.0 (2024-11-17)
- Upgraded to Grafana 11.3 and updated dependencies (#80)
3.2.0 (2024-07-29)
Breaking Changes
- Requires Grafana 10.2 or Grafana 11
- Added variables support in Dashboard Scene (#75)
- Introduced Grafana alerts with state tracking (#76)
3.1.0 (2024-07-16)
- Raised minimum Grafana version to 10.1.0 (#72)
- Added request to retrieve dashboard metadata (#70)
- Implemented data source health check (#71, #73)
3.0.0 (2024-07-11)
Breaking Changes
- Requires Grafana 10.1 or Grafana 11
- Updated tutorial in README (#57)
- Refactored code and updated ESLint configuration (#61)
- Added plugin E2E tests and removed Cypress (#64)
- Prepared for Grafana 11 (#66)
- Updated E2E tests to use Docker (#68)
- Upgraded to Grafana 11.1.0 dependencies (#60, #69)
2.2.0 (2023-09-19)
- Moved API methods under feature flags for Grafana version support (#53)
- Added option to disable Alert Rules in annotations (#55)
- Included values field from annotation text (#30)
2.1.0 (2023-09-10)
- Refactored API and increased test coverage (#50)
- Updated ESLint configuration (#50)
- Added local mode for accessing Grafana instance (#51)
- Added support for organization users (#52)
2.0.0 (2023-07-17)
Breaking Changes
- Requires Grafana 9 or Grafana 10
- Upgraded to Grafana 10.0.2 (#31, #40, #45, #47)
- Added Annotations tutorial to README (#33)
- Included authentication in Getting Started section (#36)
- Added exception handling for Alert Rules in annotations (#39)
- Updated tests with
@testing-library/react(#42) - Added tests for components and data source (#44)
- Migrated to Plugin Tools 1.5.2 (#45)
- Updated to Node 18 and latest npm (#45)
- Introduced Cypress E2E testing (#48)
1.2.0 (2023-03-30)
- Added formatted labels for alerts and set default annotation limit to 100 (#19)
- Included Alert Rules and UID for annotations (#20)
- Updated scoped variables for annotations (#21)
- Added general variable support (#25)
- Enhanced provisioning for testing alerts (#26, #28)
- Added Annotations tutorial (#29)
1.1.0 (2023-03-15)
- Updated to Grafana 9.4.3 (#13)
- Improved Bearer token configuration (#13)
- Signed as community plugin (#14)
- Updated Grafana types and description (#15)
1.0.0 (2023-03-02)
- Initial release based on Volkov Labs ABC Data Source template
- Updated README and configuration (#1)
- Added Postgres support for alerting (#2)
- Introduced annotation functionality (#3)
- Renamed to Grafana HTTP API (#4)
- Improved annotations with Timescale support (#5)
- Enhanced data source to verify organization (#6)
- Added notifications and increased test coverage (#7)
- Added annotation filters (#8) and alert states filter (#9)
- Added health and data source checks (#10)
- Finalized README for release (#11, #12)
