Plugins 〉Breadcrumb
Dependencies
Grafana
Developer
Last updated
Bring your crew,
save up to 20%
Don't miss out—Be the first to dive into Grafana 12, Prometheus 3.0, and our nearly sold-out hands-on labs on Grafana as Code, OpenTelemetry, and more.
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Breadcrumb
- Overview
- Installation
- Change log
- Related content
Breadcrumb Panel Plugin for Grafana
This is a panel plugin for Grafana. It keeps track of dashboards you have visited within one session and displays them as a breadcrumb. Each dashboard is added only once to the breadcrumb. You can navigate back to some dashboard in breadcrumb by clicking the dashboard name link text. When navigation back all items coming after the selected dashboard will be removed from the breadcrumb. Note that breadcrumb can track only dashboards that have breadcrumb panel on them.
To understand what is a plugin, read the Grafana's documentation about plugins.
Options
Is root dashboard - Panel has an option for setting it as the root. If set, this will clear breadcrumb in root dashboard. Hide text in root dashboard - Don't show anything if breadcrumb has only one item Limit the amount of breadcrumb items to - The amount of breadcrumb items is limited by default. The oldest item is removed when exceeded.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Breadcrumb on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Breadcrumb from the commandline:
grafana-cli plugins install
Changelog
1.2.0 2022-08-15
Changed from Angular.js panel to React panel
1.1.7 2019-10-07
Restrict the number of breadcrumb items. Option for not showing only one item. Angular.js version
