Plugins 〉TAVS Spinner
TAVS Spinner
TAVS Spinner Panel for Grafana
Animated spinner panel with rotation speed based on metric values. Perfect for visualizing real-time metrics with dynamic animation.
Features
- ⚡ Speed based on metrics - Rotation speed changes based on data values
- 🔢 Multiple segments - Choose from 1 to 6 line segments
- 🎨 Fully customizable - Colors, sizes, and display options
- 📊 Real-time display - Show current value in center
- 🎯 Smooth animation - 60 FPS smooth rotation
- ⚙️ Easy configuration - Intuitive settings panel
Installation
For Grafana Cloud:
- Open your Grafana Cloud instance.
- Go to Plugins → Browse.
- Search for "TAVS Spinner".
- Click Install.
For Self-Hosted Grafana:
- In your Grafana instance, navigate to Plugins → Browse.
- Click Install and restart Grafana if required.
Manual Installation (development):
git clone https://github.com/Team-Advanced-Visualization-Solutions/tavs-spinner-panel.git
cd tavs-spinner-panel
npm install
npm run build
Copy dist/ to your plugins directory
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing TAVS Spinner on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install TAVS Spinner from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.0 (Unreleased)
Initial release.
