Plugins 〉Indoor Map
Indoor Map
Grafana Plugin: Map Panel
Visualize image files for indoor maps.
Overview / Introduction
Panel that visualizes an indoor map (collection of layers of spatial data using the same frame of reference).
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Indoor Map on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Indoor Map from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.0 (Unreleased)
Initial release.
