Plugins 〉Trend Panel
Trend Panel
Description
This grafana panel displays trend panels based on the data source most recent time aggregation. It is possible to tune the thresholds and to limit the number of graphics per line.
The plugin was tested with Elastic Search 7.0 as data source. The trend is computed between the last and previous date aggregation of the serie.
Screenshots
Showcase
Panel Options
Datasource
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Trend Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Trend Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
2.0.15 (Released)
Initial grafana release.
