Plugins 〉Status Overview Panel
Status Overview Panel is an ideological continuation of the Status Panel plugin, written on the latest framework supported by Grafana. The plugin's task is to display the worst status of any component based on various metrics or one of the metrics of that component. In this context, the component can be any server, application, IT system, or anything else you can think of, combining metrics into a single entity. The main feature of the plugin is the visual representation of the component's status changes. We achieve this with a large panel displaying the component's name, the display of all metrics or metrics influencing the status change, as well as a flashing effect when the status changes. Audio notifications are also planned for the future.
More info on github Status-Overview-Panel
Preview
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Status Overview Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Status Overview Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
[v0.0.4] (dev-release)
Released at 17-06-2023
Added
- Selecting metrics by regular expression
- Replacing the name of the metric by regular expression
Changed
- Changed error display for duplicate metrics
Fixed
- Small fixes
[v0.0.3] (dev-release)
Released at 11-05-2023
- Initial release.
