Plugins 〉Orchestra Cities Icon Stat Panel
Orchestra Cities - Icon Stat Panel
This plugin extends Grafana Stat panel with icons support. More info at https://grafana.com/docs/grafana/latest/visualizations/stat-panel/
Icons supported are from FontAwesome
Options available:
- Icon selection
- Icon position selection (title or value)
- Custom title
- Custom prefix
- Custom suffix (will be combined with the unit if present)
- Trend (it displays an arrow showing the trend of the data)
It requires Grafana >=8.2.0
What is Grafana Panel Plugin?
Panels are the building blocks of Grafana. They allow you to visualize data in different ways. While Grafana has several types of panels already built-in, you can also build your own panel, to add support for other visualizations.
For more information about panels, refer to the documentation on Panels
Set up dev environment
See Contributing
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Orchestra Cities Icon Stat Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Orchestra Cities Icon Stat Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.2.3
- Sign with public key
- Bump follow-redirects from 1.14.4 to 1.14.8
1.2.2
- Remove code for color fixing (this can be custom set using overrides)
- Improve spacing
1.2.1
- Fix spaces between icon and values
- In case of no value use no color style
1.2.0
- Migrate the plugin from Angular to React to increase compatibility with Grafana 7.x.
1.1.1
- Handheld devices style improvement.
1.1.0
- Actuators Modal - show all fields and values related with query.
- Allow multiple timeseries and allow consulting details.
- Minor fixes.
1.0.0
- Ability to change the value displayed in the panel by clicking on it.
- Text color modified to near white.
- Trend indicator.
0.1.0
- Singlestat panel has external plugin.
- Add custom title with icon to the panel's top.
