Plugins 〉Compass
Developer
OceanDataTools.org
Panel
community
Compass
  • Overview
  • Installation
  • Change log
  • Related content
Compass Panel
Grafana Marketplace GitHub Sponsor License
Overview / Introduction
Compass is a Grafana visualization plugin for displaying heading or orientation data on a compass dial.
It is especially useful for ship navigation, robotics, UAVs, or any time-series data representing direction in degrees (0–360). Optionally the panel can display true and/or apparent wind angle.
Compass with Wind Indicators Example
Features
  • Smoothly animated compass dial that rotates with heading values.
  • Multiple needle types:
    • Default: classic north/south needle with red tip.
    • Arrow: bold arrow-style needle.
    • Ship: minimal ship silhouette pointing forward.
    • Custom SVG: load your own vector as a needle.
    • Custom PNG: load your own bitmap as a needle.
  • Cardinal direction labels (N/E/S/W).
  • Configurable colors for bezel, dial, text, needle, and tail.
  • Minor and major tick marks for easy orientation.
  • Optional numeric heading readout (e.g. 273°).
  • Optional indicator and numeric heading for true wind direction.
  • Optional indicator and numeric heading for apparent wind direction.
  • Optional numeric display for true wind speed.
  • Optional numeric display for apparent wind speed.
Getting Started
  1. Install the plugin by copying it into Grafana’s plugin directory or installing from the Grafana Marketplace.
  2. Restart Grafana.
  3. Add a new panel and select Compass as the visualization.
  4. Configure the data source and select the field representing heading (0–360 degrees).
Options
Data Options
  • Heading Field: Select the numeric field in your series that represents heading in degrees.
  • Truewind Direction Field: Select the numeric field in your series that represents truewind direction in degrees.
  • Truewind Velocity Field: Select the numeric field in your series that represents truewind velocity in degrees.
  • Apparent wind Direction Field: Select the numeric field in your series that represents apparent wind direction in degrees.
  • Apparent wind Velocity Field: Select the numeric field in your series that represents apparent wind velocity in degrees.
Display Options
  • Show Labels: Toggle cardinal direction labels (N/E/S/W).
  • Show Numeric Heading: Display a numeric degree readout below the compass.
  • Truewind Velocity UOM: Select the unit of measure for the truewind.
  • Apparent wind Velocity UOM: Select the unit of measure for the apparent wind.
  • Rotation Mode: Select to rotate the needle (North up) or rotate the dial (Bow up).
Needle Options
  • Needle Type
    • Default – Red-tipped classic compass needle
    • Arrow – Stylized arrow needle
    • Ship – Simplified vessel silhouette (points to heading)
    • SVG – Load a custom vector (provide URL or relative path)
    • PNG – Load a custom image (provide URL or relative path)
  • Needle Color: Color of the primary needle.
  • Tail Color: Color of the tail (for default needle).
  • Custom SVG: Path/URL to your own SVG asset.
  • Custom PNG: Path/URL to your own PNG asset.
Colors
  • Dial Color – Background color of compass dial.
  • Bezel Color – Color of outer rim.
  • Text Color – Color of labels, ticks, numeric heading.
  • True Wind Color: Color of the true wind indicator and labels.
  • Apparent Wind Color: Color of the apparent wind indicator and labels.
Screenshots
Default Needle
Arrow needle with labels and numeric heading enabled
Arrow Needle
Ship Needle
Ship silhouette needle for vessel heading visualization
Custom Styling
Standard needle compass with custom styling
North Up Orientation
North up orientation for wind indicator visualization
Bow Up Orientation
Bow up orientation for wind indicator visualization
Installing Compass on Grafana Cloud:
Changelog
1.0.0
Initial release.
2.0.0
Added wind direction indicators/labels
2.1.0
Added wind velocity labels
2.1.1
Updated links on README pages
2.1.2
Updated "No data" behaviors Biased png needle image to better indicate which end of the needle is the front.
2.1.3
Fixed: Apparent wind angle corrently displays relative to the vessel heading and NOT the compass dial.
