Plugins 〉Annotation Panel
The Annotation Panel plugin has been deprecated and is no longer maintained.
Annotation Panel
Annotations Panel for Grafana
This Grafana panel lets you save annotations in InfluxDB database. It provide a way to mark points on the graph. These points are displayable with InfluxDB Annotations feature.
Screenshots
Panel
Option Editor
Features
Actually this panel works only with InfluxDB data sources.
Changelog
v0.0.1
- first working version. Only for influxDB
Roadmap
- handle other datasources
Author
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Annotation Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Annotation Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
