Plugins 〉Percentage Trend
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Percentage Trend
- Overview
- Installation
- Change log
- Related content
Grafana Percent Trend Stat Panel
A panel plugin for Grafana >= 8.1.0 which computes and displays percent with trend compared to a previous value in a stat style big value manner.
Configuration allows to display the percentage value compared to the base value plain or interpret the percentage change as difference ("trend") with a colored (green/red) triangle symbol to see the trend evolution easily.
The idea for this plugin panel was inspired by an article about Embedded Analytics.
This plugin is reviewed by Grafana engineers and released on GrafanaLabs, see Plugins -> Panel (Community): Percentage Trend
Install
Download the latest release (named
nikosc-percenttrend-panel-<version>.zip
) and unzip it in your grafana plugin folder.
Usage
Query two metrics, remember field names, which have to be specified in the next step
Select the field names of the query results and use them to display your percentage trend
More resources
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Percentage Trend on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Percentage Trend from the commandline:
grafana-cli plugins install
Changelog
1.0.8 (2024-01-23)
- Show percentage value if base value (ie. from previous time range) is not available.
1.0.7 (2022-11-06)
- Fixed prefix in case of negative percentage trend
1.0.6 (2022-10-25)
- Support locale unit for percentage value (thanks @itsnull12)
- Allow to specify number of decimals displayed for percentage value
- Improved display in case no previous ("base") value available instead of infinity
- Improved display of stagnation (= 0% difference to base value)
1.0.5 (2022-10-19)
- Allow to invert colorization of trend (thanks @jammiemil)
1.0.4 (2022-10-07)
- Turned screenshot images from README from relative to absolute URLs
- Submission to Grafana Community
1.0.3 (2022-10-05)
- Checked backward compatibility, set from 7.0.0 to 8.1.0
- Improved check for existence of referred data frames (kudos to Esteban)
1.0.2 (2022-10-04)
- Avoid usage of deprecated UI theme and style setup
- Fixed bug when using pixel to specify percentage value size
1.0.1 (2022-09-30)
- Added logo
1.0.0 (2022-09-29)
- Initial release
