Plugins 〉Plotly
Plotly
Plot.ly Panel for Grafana
Render metrics using the plot.ly javascript framework
Works with grafana 4, 5, and 6
Screenshots
Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
yarn build
Releasing
This plugin uses release-it to release to GitHub.
env GITHUB_TOKEN=your_token yarn release-it patch
Changelog
v0.0.6
- Fix axis range configuration bug #49
 - Add basic annotations support #57 (tchernobog)
 - Improve loading times for plotly.js and support loading from CDN
 - Assume date x-axis when 'auto' and the mapping has 'time'
 - Support Fixed-Ratio Axes
 - Tested with Grafana 6
v0.0.5
- Upgrade plotly (v1.41+)
 - Better support for light theme. (#24, @cscheuermann81)
 - Support snapshots
 - Removing
distfrom master branch - Support of multiple time series's (#9, CorpGlory DevTeam)
 - Support showing text from query (#11)
 - Template variable support
 - Improved metric mapping
 - Using webpack and basic jest tests
v0.0.4
- Load plotly from npm (v1.31.2+)
 - Convert to TypeScript
 - Reasonable behavior when adding single metric
 - Formatting with prettier.js
 - Support for a single table query
v0.0.3
- Improve options UI
 - Added range mode: "tozero" and "nonnegative"
 - Map metrics to X,Y,Z and color
 - Can now select 'date' type for each axis to support time
 - basic support to size marker with data
v0.0.2
- Added ability to set color from a metric query. (#4, @lzgrablic01)
 - Show 3D axis names properly
 - Fix initalization to work with 4.2+ (isPanelVisible undefined)
v0.0.1
- First working version
Wishlist (help wanted)
- sizeref helper. I think this depends on the data. likely need to find the range and pick a good value? From react?
 - nice to have: https://plot.ly/javascript/parallel-coordinates-plot/
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Plotly on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Plotly from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
