Plugins 〉Histogram
Histogram
Histogram Panel Plugin for Grafana
This plugin show the Histogram of time series data.
How this plugin works
This plugin receives raw time series data, and count each value occurrence, and then show the occurrence as histogram.
Supported Datasources
I confirmed this plugin work with following datasource.
- Prometheus
But, this plugin can handle time series data (defined by Grafana plugin interface).
Should work with Graphite / InfluxDB / OpenTSDB.
Options
- Bucket Size
- Can configure bucket size to make histogram data.
Known Issues
- This plugin doesn't support Elasticsearch aggregation.
- As noted above, this plugin make histogram data in plugin.
- Can't handle the Elasticsearch aggregation result yet.
Changelog
v0.1.6
- Support Grafana 4.0
v0.1.5
- Refactoring
v0.1.4
- Add template variable support
- Add bucket mode
- Fix sorting of buckets
- Fix tooltip display
v0.1.3
- Fix avg legend
v0.1.2
- Add min/max option
v0.1.1
- Update document
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Histogram on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Histogram from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
