Plugins 〉Satellite Visualizer
Developer
Lucas Brémond
Panel
community
  • Overview
  • Installation
  • Change log
  • Related content
Dynamic JSON Badge
A satellite visualization panel plugin for Grafana based on CesiumJS.
Settings
  1. Set Access token with a Cesium ion access token (security best practices).
  2. (optional) Set Asset ID with ID of the glTF asset stored in Cesium ion.
Data
This plugin needs a data series with 8 columns:
Column #Description
1Time
2Longitude (deg) / x_ECI (m) / x_ECEF (m)
3Latitude (deg) / y_ECI (m) / y_ECEF (m)
4Altitude (m) / z_ECI (m) / z_ECEF (m)
5-8Orientation in inertial frame (x, y, z, s quaternion)
References
Installing Satellite Visualizer on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Satellite Visualizer from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (Unreleased)
Initial release.
