Plugins 〉Topology Panel
The Topology Panel plugin has been deprecated and is no longer maintained.
Topology Panel
Topology Panel
Topology Panel is an Sigma.js-based plugin for Elasticsearch and InfluxDB.
Install
- Clone source code from github.com repository
git clone https://github.com/gretamosa/gretamosa-topology-panel.git
- Install dependencies
npm i
- Compile plugin
npm run build (or grunt)
- Restart Grafana server
sudo service grafana-server restart
Changelog
1.0.0
Initial release
License
Topology panel is distributed under GPL-3.0 License.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Topology Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Topology Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
