Plugins
Sqlyze Datasource logo
Sqlyze Datasource
Grafana Labs
Get plugin
Grafana Sqlyze Data source
A Grafana data source plugin that connects to hundreds of datasources using one language: SQL. Connect to your favorite SQL databases, NoSQL databases, and many other non-SQL sources...and query them with SQL.
This plugin is not yet supported in Grafana Cloud.
The data source uses ODBC
This plugin has a dependency on ODBC. Windows/Linux/MacOS all support ODBC. Some dependencies may need to be installed.
Using ODBC with Linux ARM or MacOS
Install or make sure unixODBC is installed
https://www.ibm.com/docs/en/db2/11.5?topic=managers-installing-unixodbc-driver-manager
This plugin requires an ODBC driver. ODBC Drivers are available through 3rd parties. See below for a list.
Time series
To format your queries for time series, simply use the alias: as time
select date_start as time, foo, avg(bar) as bar
from foo_bar
Short list of known drivers and settings
DB2
Setting Example Value
Driver /Applications/dsdriver/lib/libdb2o.dylib
Timeout (seconds) 10
host 127.0.0.1
port 50000
uid db2inst1
pwd ••••••••••••
database sample
Impala
Databricks
Third party drivers
Settings vary per driver. This plugin allows any key/value pair to support various ODBC drivers.
