Plugins 〉Sierra Plot
Developer
boazreicher
Panel
community
Sierra Plot
  • Overview
  • Installation
  • Change log
  • Related content
Sierra Plot Grafana Panel Plugin
logo
Documentation can be found here
Sierra Plot is a Grafana panel plugin for visualizing datasets containing a very large number of series
A Sierra Plot is an extension of the Ridgeline Plot, with a number of additional elements and features. See the documentation to learn more
2000 200 mortality1 mortality2 covid19 requests requests2
pages-build-deployment
CI
Release
Installing Sierra Plot on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Sierra Plot from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (Unreleased)
Initial release.
