Plugins 〉Organization Panel
Organization Panel
Organization Panel
Introduction
Switch Grafana organizations via dropdown menu or buttons.
Inspired by Organisations Panel and Business Variable Panel.
Getting Started
The Organization Panel can be installed from the Grafana Plugins catalog or utilizing the Grafana command line tool.
For the latter, please use the following command.
grafana-cli plugins install blueswen-organization-panel
License
Apache License Version 2.0, see LICENSE.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Organization Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Organization Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
2.0.0 (2025-05-11)
- Use ComboBox instead of Select for Grafana version >= 11.5
1.0.3 (2025-03-06)
- Update plugin.json
1.0.2 (2025-03-05)
- Update README.md
1.0.1 (2025-03-02)
- Update LICENSE
- Support attestation
1.0.0 (2025-03-02)
- First release
