Plugins
PanelCommunity
Echarts logo
Echarts
bilibala
Get plugin
This plugin has been deprecated as it is no longer maintained. Consider use of Apache ECharts panel as an alternative.
Grafana Echarts Panel
release issues stars
Echarts panel for grafana 6.3+ & 7.0+, coding with react.
Code editor is attached in the edit panel to configure the option of Apache ECharts (incubating).
Support echarts-wordcloud, echarts-liquidfill and echarts-gl.
screenshot
How Use
  1. Download the packaged plugin.
  2. Or clone this repo and run yarn build.
  3. Move folder to "/grafana_path/data/plugins".
  4. Restart grafana.
Tips
  1. Echarts option in the edit panel will execute when the data from grafana is refreshed, so you should avoid side effects or ensure that the side effects of the last execution can be cleared.
function (data, theme, echartsInstance, echarts) {
  echartsInstance.off('click') // clear side effects
  echartsInstance.on('click', () => {
    console.log('Click!');
  return {...}
  1. Add Map: clone repo, add YourMap.json to src/map and run yarn build, panel will auto register it(echarts.registerMap('YourMap', {...})).
Custom
This plugin build with @grafana/toolkit. For more information about panels, refer to the documentation on Panels
  1. Install dependencies
yarn install
  1. Build plugin in development mode or run in watch mode
yarn dev
yarn watch
  1. Build plugin in production mode
yarn build
Insights
  • Adoption
    Running on 5,686 active Grafana instances.
  • Activity
    Last updated 19 Jan 2024.
    0 releases in the past year.
Version
2.2.4
Dependencies
  • Grafana >=6.3.0
Developer
bilibala
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
