Plugins 〉Vega
Vega
Grafana-Vega
This is a panel plugin for Grafana that allows you to configure Vega or Vega-Lite specs.
Features
The ability to write Vega/Vega Lite specs, which are much more powerful than the inbuilt Grafana vizes. (Gallery). <3 Vega.
A JSON editor with the Vega specs hooked up to it for autocomplete
Field names and Datasource names also hooked up to autocomplete
Automatic light/dark mode as per your Grafana theme
An obsessive amount of mucking about with React to stop your spec being reparsed all the time
{"width": "container"}hooked up to work like you want
Todo
Rig up Edit in Vega Editor and the other things you expect from Vega Embed
Dig into if it's possible to cope when Grafana sends us multiple dataframes with the same name/refId
Get it signed
Acknowledgements
The Vega project, you guys rock.
Sam Schick's prior art doing the same thing, https://github.com/schicks/vega-grafana
Gapit's generic HTML plugin, https://grafana.com/grafana/plugins/gapit-htmlgraphics-panel/ , which I used as a reference to get the nice editor working, and additionally for letting Vega panels be used in a pinch before I wrote this!
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Vega on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Vega from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.11
- Switch bundler to Vite for AMD support
1.0.10
- Fix rich text in schema autocomplete
1.0.9
- Fix endless rerender loop when editing
1.0.8
- Ensure provisioning works
1.0.7
- Make dark theme better
1.0.6
- Wire up Vega support (previously just Vega-Lite worked)
1.0.4
- Initial release.
