1 Node Exporter 1.0.1
Dashboard
Host Metrics (VM, Server, OS) https://github.com/fchiorascu/Observability
Last updated: a year ago
Start with Grafana Cloud and the new FREE tier. Includes 10K series Prometheus or Graphite Metrics and 50gb Loki Logs
Reviews: 4
This dashboard is Dynamic where you can have the metrics for: 1 VM, Multiple VMs or All VMs.
Metrics:
  • UP
  • Load
  • CPU
  • RAM
  • NTP
  • Disk
  • Swap
  • Forks
  • Inodes
  • Kernel
  • Uptime
  • Entropy
  • Threads
  • Network
  • Systemd
  • Interrupts
  • Processes
  • File Descriptors
  • Switches Context
Versions:
  • Grafana: 7.4.0+
  • Prometheus: 2.24.1+
  • Node Exporter: 1.0.1+
Interval and range variables: http://docs.grafana.org/features/datasources/prometheus/
  • Support for $__range, $__range_s and $__range_ms only available from Grafana v5.3
  • It’s possible to use some global built-in variables in query variables; $__interval, $__interval_ms, $__range, $__range_s and $__range_ms, see Global built-in variables for more information. These can be convenient to use in conjunction with the query_result function when you need to filter variable queries since label_values function doesn’t support queries.
  • Make sure to set the variable’s refresh trigger to be On Time Range Change to get the correct instances when changing the time range on the dashboard.
Collector Configuration Details
Prometheus configuration: /opt/prometheus/prometheus.yml
- job_name: server1
  static_configs:
    - targets: ['192.168.1.10:9100']
      labels:
        env: prod
        alias: server1
Node Exporter Service: $ cat /usr/lib/systemd/system/node_exporter.service
 [Unit]
 Description=Prometheus Node Exporter
 Wants=network-online.target
 After=network-online.target
 [Service]
 User=node_exporter
 Group=node_exporter
 Type=simple
 ExecStart=/opt/node_exporter/node_exporter --web.listen-address=0.0.0.0:9100 --log.level=info --log.format=json --collector.logind --collector.systemd --collector.tcpstat --collector.ntp --collector.interrupts  --collector.meminfo_numa --collector.processes --no-collector.bonding --no-collector.bcache --no-collector.arp --no-collector.edac --no-collector.infiniband --no-collector.ipvs --no-collector.mdadm --no-collector.nfs --no-collector.nfsd --no-collector.textfile --no-collector.wifi --no-collector.hwmon --no -collector.conntrack --no-collector.timex --no-collector.zfs --collector.systemd.unit-whitelist=(crond|sshd|node_exporter)\\.service
 ExecReload=/bin/kill -HUP $MAINPID
 TimeoutStopSec=10s
 SendSIGKILL=no
 SyslogIdentifier=prometheus_node_exporter
 Restart=always
 [Install]
 WantedBy=multi-user.target
