Infrastructure Monitoring - USE Framework
Infrastructure monitoring template using the USE (Utilization, Saturation, Errors) methodology. Monitor Kubernetes clusters from nodes to pods with resource metrics, bottleneck detection, and stability tracking. Ready for instant integration with Prometheus or other datasources.
Infrastructure Monitoring - USE Framework screenshot 1
Infrastructure Monitoring - Template dashboard
RevisionDescriptionCreated
Splunk Infrastructure Monitoring
by Grafana Labs
Grafana Labs solution
With the Grafana plugin for Splunk Infrastructure Monitoring, you can quickly visualize your metrics and analytics in Grafana.
Import the dashboard template
Datasource
Dependencies
