K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana11, 2025, EN)
Centralized Multicluster Monitoring / Node Metrics / Multi-Job Selection / Grafana 11 / Reference 11074
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana11, 2025, EN) screenshot 1
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana11, 2025, EN) screenshot 2
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana11, 2025, EN) screenshot 3
Original Source (11074)
Custom Changes (22413)
  • Latest: https://github.com/YunanJeong/cmm
  • Support Grafana 11.3
  • Support Dynamic Selection for Multi-DataSource(Prometheus)
  • Support English
    • 11074's style is very useful. Also, 11074's publisher supports other advanced dashboards(like 16098)
    • BUT, they only support Chinese in the latest Grafana.
  • Default Settings of Table minWidth for Vertical Mode
  • Modify the design of some panels
    • Total CPU, Total Memory, Total Disk
  • Delete Links
    • Redirection via Link URL is unstable in the latest Grafana. Please just use label selection.
UseCase
  • We are operating multiple Kubernetes clusters, and have deployed node-exporter and prometheus to each cluster using the kube-prometheus-stack helm chart.
  • We want to monitor metrics of multiple clusters in a centralized monitoring environment(1 dashboard, 1 Grafana).
RevisionDescriptionCreated
Kubernetes
Kubernetes
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
