Temperature and Humidity Monitor
This Grafana dashboard provides temperature and humidity metrics using Prometheus, and is a reference sample for the sensor-data-monitoring-grafana project.
This Grafana dashboard provides a comprehensive overview of temperature and humidity metrics and uses Prometheus as the data source. It is a reference sample from the GitHub project sensor-data-monitoring-grafana and is specifically designed to work within that context.
