AWS Serverless Observability Monitoring
This is part of our 🚀AWS Native Cross-account Observability Dashboard! This dashboard offers deep insights into the AWS Serverless using the Cloud Native components. It spans all accounts within your organization.
AWS Serverless Observability Monitoring screenshot 1
AWS Serverless Observability Monitoring screenshot 2
AWS Serverless Observability Monitoring screenshot 3
AWS Serverless Observability Monitoring screenshot 4
AWS Serverless Observability Monitoring screenshot 5
AWS Serverless Observability Monitoring screenshot 6
Getting Started
To get started with the AWS Serverless Observability Monitoring, please follow our project site's instructions on GitHub.
Short descriptions
✅ Features
🔴API Gateway Request and Error Monitoring:- Track Recent API Gateway Requests: View the latest 300 API Gateway requests with detailed metadata, including IP addresses, request methods, and response statuses.
- Error Analytics: Spot errors (4xx and 5xx) instantly, with the ability to drill down into error details for troubleshooting.
🟠AWS Lambda Performance Insights:- Track Recent Lambda Executions: Examine detailed logs for the most recent Lambda invocations, including execution status, request ID, and X-Ray trace information.
- Enhanced Lambda Debugging: Easily filter and find Lambda execution logs tied to specific API requests using correlation IDs from API Gateway and trace IDs.
🔵AWS X-Ray Trace Monitoring:- Real-time Trace Visualization: Get a complete visual breakdown of API Gateway requests and Lambda invocations using X-Ray traces. Trace the path of a request as it moves through API Gateway, Lambda, and DynamoDB using Service Map.
- Detailed Latency Breakdown: Understand the latency of each service involved in a transaction, helping you identify performance bottlenecks at a glance with the Flame Graph.
Centralized 🔴CloudTrail Logs:- Cross-Service Correlation: Track recent AWS API requests. Easily identify and troubleshoot issues across multiple services, including who called the API and from where.
RevisionDescriptionCreated
AWS
AWS
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
