k6 Load Testing Results Simple filters
A dashboard for visualizing results from the k6.io load testing tool, using the InfluxDB exporter. It supports http, ws, grpc, ... metrics
k6 Load Testing Results Simple filters screenshot 1
k6 Load Testing Results Simple filters screenshot 2
k6 Load Testing Results Simple filters screenshot 3
k6 Load Testing Results Simple filters screenshot 4
export K6_INFLUXDB_USERNAME=login
export K6_INFLUXDB_PASSWORD=password
export K6_INFLUXDB_PUSH_INTERVAL=3s
export K6_SUMMARY_EXPORT=summary.json
export K6_NO_USAGE_REPORT=true
k6 run --out influxdb=http://influxdb:8086/k6 ./scenario.js
It supports http, ws, grpc, kafka, ... metrics.
You feel free to add any of them in one variable. It has APDEX as well
Based on https://grafana.com/dashboards/4411
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
