Internet Speed Test (speedtest)
Results of speed test CLI.
Using Telegraf speedtest configuration (change the interval to your needs and remove server_id_include if wanted):
[[inputs.internet_speed]]
interval = "24h"
server_id_include = [ "61186" ]The server_id_include setting allows me to always use the same test server, update or remove this section if you want to.
Note: This Telegraf plugin is using speedtest-go that performs the measurements: https://github.com/showwin/speedtest-go
