Azure / Infrastructure / Storage and Key Vaults Monitoring
This dashboard displays traffic-light indicators to show the health of your Azure infrastructure resources based on key performance indicators and thresholds defined for each infrastructure resource type. The KPIs and thresholds come from Azure Monitor Baseline Alerts (https://azure.github.io/azure-monitor-baseline-alerts/). Prerequisites: The queries used in the dashboard require that you have resource metrics being sent to a Log Analytics Workspace. The AzureMetrics and AzureDiagnostics tables are required. This can be achieved through a resource’s diagnostic settings. For detailed instructions, refer to Azure Monitor Essentials: Diagnostic Settings: https://learn.microsoft.com/en-us/azure/azure-monitor/essentials/diagnostic-settings#metrics This is one of a collection of dashboards linked together via dashboard links and the "azure-infra-monitor" tag. Other dashboards in the collection include: Azure / Infrastructure / Network Monitoring Azure / Infrastructure / Apps Monitoring Azure / Infrastructure / Compute Monitoring Azure / Infrastructure / Data Monitoring The other dashboards in this collection can be found in the Azure Monitor Team Grafana library here: https://grafana.com/orgs/azure/dashboards. Once imported, you will be able to access these dashboards using the Azure Infra Monitoring Dashboards tab.
This dashboard displays traffic-light indicators to show the health of your Azure infrastructure resources based on key performance indicators and thresholds defined for each infrastructure resource type. The KPIs and thresholds come from Azure Monitor Baseline Alerts.
Prerequisites
The queries used in the dashboard require that you have resource metrics and diagnostics being sent to a Log Analytics Workspace. The AzureMetrics and AzureDiagnostics tables are required. This can be achieved through a resource’s diagnostic settings. For detailed instructions, refer to Azure Monitor Diagnostic Settings
Infrastructure Dashboard Collection
This is one of a collection of dashboards linked together via dashboard links and the “azure-infra-monitor” tag. Other dashboards in the collection include:
- Azure / Infrastructure / Data Monitoring
- Azure / Infrastructure / Network Monitoring
- Azure / Infrastructure / Apps Monitoring
- Azure / Infrastructure / Compute Monitoring
The other dashboards in this collection can be found in the Azure Monitor Grafana Library. Once imported, you will be able to access these dashboards using the Azure Infra Monitoring Dashboards tab.
Azure Cosmos DB
