Prometheus system
Prometheus for system metrics. Load, CPU, RAM, network, process ...
Prometheus system screenshot 1
Prometheus system screenshot 2
Show classical system metrics of your servers. It's also linked alerts of the selected servers (if alert are set). Need to use tag name for servers. The tag used is "alias" but you can change it in templating.
Open issues or give feedback at : https://github.com/tcheronneau/grafana_dashboard
RevisionDescriptionCreated
Metrics Endpoint (Prometheus)
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
