Sense Collector - Device Overview
**Device Overview** is the main dashboard for Sense Collector.
Device Overview is the main dashboard for Sense Collector. Here, you'll see several sections about the device's overall details.
Current Wattage: A Bubble Chart showing current wattage usage by device. Larger circles represent higher wattage consumption.
Wattage By Device (Stacked): Wattage overtime per device. The graph is stacked to represent total household wattage.
Device Status: This is a State Timeline representing event data from the Sensor Monitor over time. It currently represents three states: On, Off, and Idle.
Event Timeline: This table view shows each device's state change.
Device Details - Average: This is a table view of current data representing the current state, state time, watts in use, average, and always on makeup. Average duration, monthly kWh, percent, and the number of runs are also listed. This table defaults to being sorted by "Watts (In Use)."
Device Details - Current Month: Shows the number of runs per device since the start of the current month.
Device Details - Yearly: This section shows each device's calculated kWh and costs. The text next to each device provides details on how the costs are calculated, such as "Based on the last 30 days," "Based on the last 7 days," or "Based on last season."
Smart Device Details: If you have any of the Sense compatible smart plugs, they will be listed here as well. Open up this row to display the voltages and amps measured by each plug. There's another measurement (Who Knows By Plugs), but I don't know what it does yet.
Always On Devices: This shows which devices the Sense monitor has detected have an Always On wattage component. This may be different from actual wattage and tends to update less frequently.
Notice: This Grafana dashboard uses the community visualization Bubble Chart panel plugin.
More details on these Sense Collector dashboards may be found:
Github Project: https://github.com/lux4rd0/sense-collector/
