SolidFire Overutilized Volumes (DEPRECATED)
NetApp SolidFire Overutilized Volume powered by https://github.com/mjavier2k/solidfire-exporter
SolidFire Overutilized Volumes (DEPRECATED) screenshot 1
DEPRECATED - NetApp SolidFire Overutilized Volumes
This dashboard is no longer maintained and will only work with versions v0.5.2 or earlier of solidfire-exporter
The over-utilized volume dashboard contains information for debugging volumes that are over-utilized (i.e. going over their allocated burst capacity.
See also:
The sfcluster label is required for the dashboard to work properly - be sure to add it in your Prometheus scrape config:
- job_name: solidfire_exporter
  honor_timestamps: true
  scrape_interval: 30s
  scrape_timeout: 20s
  metrics_path: /metrics
  scheme: http
  static_configs:
  - targets:
    - localhost:9987
    labels:
      sfcluster: sfcluster01
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
