Docker and system monitoring
A simple overview of the most important Docker host and container metrics. (cAdvisor/Node Exporter/Prometheus) updated from ID 893 by Thibaut Mottet
Docker and system monitoring screenshot 1
Docker and system monitoring screenshot 2
Docker + System dashboard
This dashboard fork from ID:893 and modify for compatible with Grafana version 7.3, cAdvisor version 0.34, node exporter version 1.0.1 and Prometheus version 2.23
System metric
This dashboard display Docker and system metric, the aim it's to have all the metric on one dashboard. The first lines represents the system metric with gauge and text/graph (easy to visualize and minimalist).
  • Host up time
  • Memory/swap usage
  • Disk usage
  • Load average
  • Network I/O
  • CPU usage
  • Disk I/O
Some alerts are disable due to new version of Gragana not allow to create alert when template variables are used.
Docker metric
The second parts of the dashboard is Docker metric, more detailed using mostly graph.
  • CPU usage per container
  • Sent network per container
  • Received network per container
  • Memory usage/swap per container
  • Remaining memory for each container (if men_limit defined in docker-compose.yml)
Server configuration
I use the docker-compose to set my monitoring: https://github.com/vegasbrianc/prometheus. My dashboard work with this configuration. Service running:
  • docker: version 19.03
  • prometheus: version 2.23.0
  • node_exporter: version 1.0.1
  • cAdvisor: version v0.34.0
  • grafana: version 7.3.4
Install with docker-compose.yml
docker-compose.yml
prometheus:
    image: prom/prometheus:latest
    container_name: monitoring_prometheus
    restart: unless-stopped
    volumes:
      - ./data/prometheus/config:/etc/prometheus/
      - ./data/prometheus/data:/prometheus
    command:
      - '-config.file=/etc/prometheus/prometheus.yml'
      - '-storage.local.path=/prometheus'
      - '-alertmanager.url=http://alertmanager:9093'
    expose:
      - 9090
    ports:
      - 9090:9090
    links:
      - cadvisor:cadvisor
      - node-exporter:node-exporter
node-exporter: image: prom/node-exporter:latest container_name: monitoring_node_exporter restart: unless-stopped expose: - 9100
cadvisor: image: google/cadvisor:latest container_name: monitoring_cadvisor restart: unless-stopped volumes: - /:/rootfs:ro - /var/run:/var/run:rw - /sys:/sys:ro - /var/lib/docker/:/var/lib/docker:ro expose: - 8080
grafana: image: grafana/grafana:latest container_name: monitoring_grafana restart: unless-stopped links: - prometheus:prometheus volumes: - ./data/grafana:/var/lib/grafana environment: - GF_SECURITY_ADMIN_PASSWORD=MYPASSWORT - GF_USERS_ALLOW_SIGN_UP=false - GF_SERVER_DOMAIN=myrul.com - GF_SMTP_ENABLED=true - GF_SMTP_HOST=smtp.gmail.com:587 - GF_SMTP_USER=myadrress@gmail.com - GF_SMTP_PASSWORD=mypassword - GF_SMTP_FROM_ADDRESS=myaddress@gmail.com
prometheus.yml
# my global config
global:
  scrape_interval:     120s # By default, scrape targets every 15 seconds.
  evaluation_interval: 120s # By default, scrape targets every 15 seconds.
  # scrape_timeout is set to the global default (10s).
Attach these labels to any time series or alerts when communicating with
external systems (federation, remote storage, Alertmanager).
external_labels: monitor: 'my-project'
Load and evaluate rules in this file every 'evaluation_interval' seconds.
rule_files:
- "alert.rules"
- "first.rules"
- "second.rules"
A scrape configuration containing exactly one endpoint to scrape:
Here it's Prometheus itself.
scrape_configs:
The job name is added as a label job=<job_name> to any timeseries scraped from this config.
  • job_name: 'prometheus'
    Override the global default and scrape targets from this job every 5 seconds.
    metrics_path defaults to '/metrics'
    scheme defaults to 'http'.
    static_configs: - targets: ['localhost:9090','cadvisor:8080','node-exporter:9100', 'nginx-exporter:9113']
Start your docker
Run docker-compose up -d
RevisionDescriptionCreated
Docker
Docker
by Grafana Labs
Grafana Labs solution
Easily monitor Docker with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
