SSL Certificate Monitor
OpenAdvices first published Dahsboard: Just one Table Widget to display the Certificate and Connection Status from HTTPS Connections that are Monitored with Prometheus.
SSL Certificate Monitor screenshot 1
SSL Certificate Monitor screenshot 2
Hi, i'm Malte from OpenAdvice and i referred to this Dashboard in my Grafana Blog post:
https://grafana.com/blog/2020/11/25/how-we-eliminated-service-outages-from-certificate-expired-by-setting-up-alerts-with-grafana-and-prometheus/"
Most Applications rely on connections to APIs, databases and maybe some authentication service. If those connection are monitored with the Prometheus Blackbox_exporter you also get the certificate status.
This Dashboard has only one panel to demonstrate how to display all connection metrics utilizing the new Grafana 7 table panel features.
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
